This is my 08 Giant Trance 0.
CrossMax SLs with Schwalbe Racing Ralphs for offroad:
Running in 'street mode', Mavic SpeedCity Rims with Vittoria Randonneur 28mm w/shielding flat protection:
Strangely, the Joplin and RaceFace seatposts in the shots above are usually on with the other wheel configuration...!
Stuff in red is changed from stock...
Frame - 2008 Trance 0 (Medium) 4.2" travel
Shock - Fox RP23 ProPedal (3 stage)
Fork - RockShox Reba Race w/Pushloc, 115mm travel
Handlebar - RaceFace Deus XC
Stem - RaceFace Deus XC 70mm
Headset - CaneCreek ZS
Grips - Lizard Skins Peaty ODI Lock-On
Saddle - Selle Italia SLR Gel Flow
Seatpost - Crank Brothers Joplin/RaceFace Deus XC
Seatclamp - Salsa Liplock
Front Brake - Avid Juicy Carbon w/185mm G2 rotor
Rear Brake - Avid Juicy Carbon w/160mm G2 rotor
Cranks - RaceFace Deus XC Triple (22/32/44) w/NC-17 chainring bolts
Chain - SRAM PC991 Hollow Pin
Pedals - Crank Brothers Acid II Carbon
Front Derailleur - Shimano XT
Rear Derailleur - SRAM X.0 w/BlackBox carbon long cage
Derailleur Cable - SRAM FlakJacket, sealed
Front Shifter - SRAM X.0
Rear Shifter - SRAM X.0
Cassette - SRAM PG990 11-34
Front Hub - Mavic SpeedCity/Mavic CrossMax SL
Rear Hub - Mavic SpeedCity/Mavic CrossMax SL
Front Rim - Mavic SpeedCity/Mavic CrossMax SL
Rear Rim - Mavic SpeedCity/Mavic CrossMax SL
Spokes - Mavic SpeedCity/Mavic CrossMax SL
Nipples - Mavic SpeedCity/Mavic CrossMax SL
Skewers - Salsa FlipLock
Tyres - Vittoria Randonneur 28mm w/shielding flat protection
Tubes - Maxxis Ultralight
Frame Protection - THE chainstay protectors
Bottle Cage - Giant Carbon
Total weight - 12kg (26.5 lbs)
