Results 1 to 10 of 14
Thread: Stripped bolt on disc brakes?
    Aug 2009
    58
    Default Stripped bolt on disc brakes?
    I was trying to use my new torque wrench to tighten the 3mm allan key bolt which holds the disc brake pads into my tektro auriga comp calipers (i think i must have not done it right as it seems like the bolts are now stripped). The bolt keeps turning in the socket no matter which way i try to turn it and i cant pull it out with pliers either since i think there is a bit of thread still on the other side which is in there.
    Any ideas of getting it out? and do you think I will be able to find a suitable replacement bolt at bunnings or something?
    it seems pretty stupid now trying to learn how to use a clicker torque wrench on something like this - i've learnt my lesson, but i sent the dial to 2nM (clearly my wrench is a piece of crap)!
    Senior Member leftykonashred's Avatar
    Nov 2008
    Newest of the Castles
    1,028
    happened to me too mate
    my mums boyfriend got this thing from bunnings
    not sure what its called
    i think it's stripped screw remover anyway they look like drill bits but you screw them in there are teeth that get caught in the bolt and then you twist it out ask them at bunnings or anywhere like that
    hope it helps
    lefty
    CHECK OUT MY YOUTUBE CHANNEL >>> https://www.youtube.com/user/GoMootyPro1080
    Senior Member dhDRucer's Avatar
    The Berg!
    608
    i once cut a bolt with a umm...small thing that does the same thing as a grinder? Anyways it had a small cutting wheel on it and just got a small slit out and used a flat head screwdriver. Or cut 2 slits and use a philips head
    Aug 2009
    17
    Quote Originally Posted by c0de View Post
    depends on if the bolts stripped, or the thread in the caliper is stripped. if the caliper is stripped it's a little harder. not sure if people use helicoils on bike brakes at all but it's a possibility. might have to tap and re-thread at the next bolt size up.
    to remove it, have you tried pushing at the back of the screw as you try to unscrew it?
    Quote Originally Posted by leftykonashred View Post
    ezy-out...
    Quote Originally Posted by dhDRucer View Post
    dremel...
    :D
    Aug 2009
    58
    Quote Originally Posted by 68deluxe View Post
    ezy-out...
    dremel...
    :D
    Thanks for the tips guys, I did try using another pin to push as i unwinded but it just turns in the socket and doesnt move anywhere.
    Yeah at the moment i dont know if its the actual caliper which is stripped itself or the bolt itself (i assumed bolt since its probably the softer metal)
    how much is that ezy out thing? dremels are like a hundred bucks from memory? might as well buy a new set of avid elixir brakes lol
    Aug 2009
    58
    actually from what the later people were posting, i havent rounded the allan key socket, i think the threads on the screw have come off the bolt, so i can turn the allan key, it just keeps rotating the bolt around and it doesnt tighten or loosen anymore
    Doesn't want a custom title! DownhillerDeano's Avatar
    Geelong
    1,086
    What do you mean by socket? The female thread i'm assuming? If so, and the bolt is stripped, it should just pull straight out
    Easy out's come in a pack of a range of sizes, and like everything, pay for what you get, there is cheap ones, there is expensive ones.
    Don't necessarily need a dremel, a hacksaw could be used to cut a slot or if your patient and catious even a file if you really had to.
    Quote Originally Posted by johnny View Post
    When you have NFI about something it's best to say nothing
    Senior Member Pebble's Avatar
    Feb 2006
    WA
    2,422
    From what I can gather you have used an allen key instead of a torx one (similar thing but different number of sides).
    So I'm thinking you have rounded out the bolts (the bolt heads).
    I did this once even having used the proper torx tool, tried to use a screwdriver but in the end what worked for me was to get a drill with a drill bit as big as the allen bolt head, you drill the head away and the remaining bolt sticking out can be unscrewed with pliers. Of course you have to excercise some caution not to drill too far and potentially into your rotor or something.
    If you do a search you will probably come across other threads where people have had the very same issue, it seems pretty common.
    Oh yeah I know I'd be pretty weary of buying a wheel (or set) that had a rotor included for free:D No I've never done it, but I've seen ads a few times and the first thing that comes to mind is that someone couldn't get the rotor off!!!
    Aug 2009
    58
    Quote Originally Posted by DownhillerDeano View Post
    I'm thinking of getting a drill and drilling off the end, its definitely an allan key bolt (it holds the brake pads, in the caliper - not talking about the rotor which is torx 25 bolts)
    And you would think that it should pull straight out if the threads on the screw thing have worn off, but the thing is the threads go a bit further than what are in the female caliper socket thing, so i think the threads in the middle are stuffed, but there is about 2-3mm on the other side of the allan bolt head which means i cant pull it out!
    problem will be finding a replacement to put back in, so i might have to visit bunnings to see if i can find some 3mm diameter threaded bolts with an allan key socket on the end before i try to drill these off.
    The brakes are working ok at the moment, but the front pads seem contaminated since they slip slightly even with maximum gripping on the levers.
    Geelong
    1,086
    No, you'll have better luck at a dedicated bolts/fasteners shop;), be cheaper too.
