Results 1 to 10 of 18
Thread: Quick Question: LS-1 to LG-1
    Nov 2007
    Melbourne.
    1,227
    Default Quick Question: LS-1 to LG-1
    As the title says, a quick question.
    I've currently got an E13 LS-1. Below.
    And I would like to run a Taco.
    Not this. This.
    But the Ls-1 does not allow. If I was just to purchase an old (not the LG1+) back plate, as they're available, would my ls-1, become this. As by the look of thing, they're essentially the same, bar the back plate.
    Therefore being Taco compatible.
    Thankyou. And i hope you enjoyed my pictorial questioning.
    daniel / lanky | bikes | flickr
    Senior Member Nerf Herder's Avatar
    8,746
    the back plate is the important bit ... as you've noticed ... your current jobbie doesn't have the taco bolt holes ...
    So ... since the roller and top guide thingy are the same bolt pattern ... your logic is good.
    Always good to have pics
    Pushie Enterprises: Find them on Facebook / PushieEnterprises and http://pushie.com.au/
    Nov 2007
    Melbourne.
    1,227
    Ok cool, I thought so. Thanks.
    It ends up a fair bit cheaper this way too. :o
    Senior Member dj3's Avatar
    Toowoomba
    1,526
    i have an LS-1 and always thought that if i wanted to run a taco, Mr. drill could make those holes? there is enough overhang to do so.
    Nov 2007
    Melbourne.
    1,227
    I considered that. But the back-plate is just a relatively thin piece of steel, and would be no where near strong enough to take a beating through a Taco.
    (Broken Taco)
    Senior Member T-Rex's Avatar
    North Shore, Sydney
    2,753
    In the House of Rex we run both LS1 and LG1s. I was just last night fitting an LS1 to T-Rex Junior's DJ/4X bike, so your question is timely.
    The top chain guide on the LS1 that I fitted last night had a different top chain guide to the LG1. As you know the LS1 has a pressed steel backing plate maybe 2mm thick, and the LG1 backing plate is aluminium more like 4 - 5mm thick. The LS1 top chain guide had a slot in it which created a lip that the steel backing plate sat in, and the aluminium backing plate on the LG1, being considerably thicker, would not fit in this slot. It might be something that you could fix with a file, but I wouldn't assume that it would just bolt right up to a LG1 backing plate.
    Edit: And assuming you don't already own a taco, have you costed buying a complete LG1 and sellig your LS1, vs buying separately a backing plate and a taco? Spare tacos are annoyingly expensive for a simple yet very exposed part that gets wiped out from time to time.
    Quote Originally Posted by Drizz
    Growing old is mandatory, growing up is optional.
    http://www.ccomtb.com.au
    Follow us on Facebook: Central Coast Ourimbah MTB
    Nov 2007
    Melbourne.
    1,227
    Hmm... Interesting. Actually I've got an old SRS in the garage, i could test the top box on, assuming it's the same as the LG-1. But I can't use this back plate on the bike as it's the old ISCG, I need ISCG '05.
    Price wise the new LG1+'s are bloody expensive ($300+ I think), and I don't think I could get much for the LS-1 second hand, as they retail for just over a hundred. But i'll defiantly look at prices in more detail now to see whether it's worth it.
    Thanks.
    Mar 2010
    Wollongong
    31
    Quote Originally Posted by U.D.O View Post
    Thanks.
    I'm in the same boat as you mate. I've got an LS-1 and I bought a taco last week assuming that it would bolt straight on. Now I'm stuck with this taco I can't use unless I get a new chain guide. When I read through the first few posts, I had hope that a new backplate would do the trick.
    Hmmm.....
    Senior Member Dales Cannon's Avatar
    Samford
    2,036
    You can buy 4 or 5t aluminium and it shouldn't be too hard to make up a new backing plate if you have a few tools like drill, saw and files. Way cheaper than all new. Alternatively look at stiffening up the pressed steel backing plate. You could bolt an aluminium plate on the back or even get another pressed steel backing plate and bolt the two together.
    Senior Member el~rio's Avatar
    Jun 2009
    Albury, NSW
    228
    $188.51 delivered .
    Quote Originally Posted by Crowey View Post
    Every time I jump on a BMX, it looks like I'm going for a goon run.
