Formerly Farkin.net - News | Forums | PotD
Thread: Rock Shox Reba 29 RL setup help
    Central Coast
    462
    Default Rock Shox Reba 29 RL setup help
    Have my new shiny bike with the Rock Shox Reba 29 RL fork. I'm at a loss on setting it up as bike came with no docs and the forks dont have any pressures printed on them.
    Searched the sram website for docs but nothing..
    Also, can anyone explain the negative pressure setting and the benefit of using more/less then the + pressure?
    Senior Member Stevob's Avatar
    Jun 2006
    On top of a hill somewhere
    1,173
    A quick Google led me to MTBR and this thread, and this comment
    NOte that the Reba SL 29 (custom for Specialized) is not called in there specifically but seems to have the same settings as Reba/Pike/Revelation Dual Air
    led to this pdf on Sram's website.
    Note that I don't use one myself. I stay rigid all the time.:p
    Central Coast
    462
    Thanks for the swift reply! Interesting info on different schools of thought for setting these things up! Gimme the simple 1 air pressure + rebound clicker anyday!
    btw, my reconstructed wrist needs something to "soften" up the trail even if its "only" 100mm ;)
    Aug 2010
    16
    i got the reba rlt on my jamis d29 i run 130 psi in both positive and negative for 80kg. run pressures the same for + & - , but yeh i still reckon my single air rockshox and my other bike is more plush
