Formerly Farkin.net - News | Forums | PotD
Results 1 to 10 of 15
Thread: 2012 Giant Reign vs 2011 Mongoose Teocali Elite
    Jun 2010
    26
    Default 2012 Giant Reign vs 2011 Mongoose Teocali Elite
    Has anyone ridden both?
    I can get the Teocali for $250 cheaper and it seems to have better spec drivetrain, brakes and wheels. Reign has better shocks but I've read some bad reviews about the hubs and can't find anything on the rims.
    The Teocali felt pretty fun but I'm a bit suss on the rear suspension performance/durability (googled reviews give mixed feedback).
    I've done the carpark test but that obviously doesn't tell too much...
    FRAME
    Sizes S:15, M:17, L:19
    Colors Black
    Frame ALUXX SL FluidFormed™ alloy Maestro 6.0” travel
    Fork Fox 32 FLOAT RL w/ 15QR axle and Tapered Steerer, 5.9”/150mm Travel
    Shock Fox Float RP2 w/XV sleeve & boost valve
    COMPONENTS
    Handlebar Giant Connect oversize alloy 670mm x 25mm rise
    Stem Giant Connect oversize alloy, 4 bolt, 8 degree
    Seatpost Giant Connect oversize alloy micro-adjust 30.9
    Saddle Fi’zi:k Gobi XM w/Manganese rail
    Pedals N/A
    DRIVETRAIN
    Shifters SRAM X-5 trigger shift 27 sp.
    Front Derailleur Shimano SLX 9 sp direct mount
    Rear Derailleur SRAM X-7 9 sp
    Brakes Avid Elixir 1 hydraulic, w/7” front & 6” rear 6 bolt rotors
    Brake Levers Avid Elixir 1 hydraulic
    Cassette Shimano HG30 9 sp 11-34T
    Chain Shimano HG53 9 sp
    Crankset Shimano M542 22x32x44T
    Bottom Bracket Shimano BB71, press fit
    WHEELS
    Rims DT 465D double wall, eyeleted, alloy 32H disc
    Hubs Fr: Giant Tracker sealed cartridge 15QR | Rr: Shimano M475 9sp disc
    Spokes 14/15G butted stainless
    Tires [F] Maxxis Minion DHF 26x2.35 [R] Maxxis High Roller 26x2.35
    OTHER
    Extras Shock pump
    Sizes: Extra Large Frame
    Frame: New Mongoose FreeDrive W/ 150 mm travel, tapered head tube, ISCG-05 mounts, and replaceable hanger
    Fork: Rock Shox Sektor RL 150 mm travel, Solo Air spring, lockout, rebound and 15 mm Maxle Lite thru axle
    Rear Shock: Ario 3.2 , air spring, rebound and lock out, 200x57 mm w/ 19x8 mm hardware
    Crank: FSA Comet 27/39T alloy
    Bottom Bracket: FSA MegaExo external bearing
    Shifters: SRAM X.7 2x10 speed
    Speeds: 27 Speed
    Front Derailleur: Shimano SLX
    Rear Derailleur: SRAM X.9 medium cage
    Wheels Size: XL
    Tires: Kenda Excavator 26x2.35 front / 2.1 rear Dual Tread Compound, folding bead
    Brake: Avid Elixir 3 hydraulic disc w/ 185 mm front /160mm rear rotors
    Handlebar: Kore Torsion Race Riser Handlebar 710 x 31.8 x 20 rise x 5 deg BB Black
    Stem: Kore B-52 0 deg. K34 Stem 65x31.8x28.6 BB Black
    Headset: FSA ZS Taper w/ACB bearigns (1.125" upper 1.5" lower).
    Brake Levers: Avid Elixir 3
    Spokes: 14g Stainless
    Grips: Mongoose Lock on
    Saddle: Kore T-Beam, 6061 forged alloy rail
    Seat Post: Kore T-Beam / I-Beam 6061 Seatpost 31.6 x 350 Satin Silver head, zero offset, BB Black shaft
    Seat Clamp: Alloy w/ QR
    E Subs, Sydney
    280
    I have owned three Teocalis.......but only bought one! The first two suffered frame failure however the last (2009 model) was fine.
    The pedalling action was very good and efficient however it certainly added to the weight. The back end weight is noticeable. Comparing it to the 2011 Trek Remedy I have now, there is a substantial difference in weight and even more so in handling. Any chance you can get your hands on a 2011 Remedy?
    I haven't ridden the Giant but given the most recent review in Dirt (Jan 2012), it seems like a very good machine.
    One important consideration that I read (and made sense after I got the Remedy) is that the action of the suspension linkage on the Teocali could potentially ramp up too much so as to never reach full travel (unless running low shock pressures). The description was more around bigger hits however.
    55
    The shocks on the reign are far better. Push your budget a bit further and get a Reign 1 - adjustable seat post, better front and rear shocks and drivetrain. Apparantly you can squeeze the shop and pick them up for $2k flat.
    How much is the Mongoose?
    Senior Member Keven's Avatar
    Oct 2009
    Oberon, NSW
    116
    I might be wrong but doesn't the 2012 Reigns come with Rockshox forks and shock?
    Jun 2010
    26
    Thanks for the feedback.
    my02 - Cheers, that's the sort of thing I wanted to find out. The Teocali seemed ok but there just seemed to be so many linkages...plus I was a little freaked out by the way the bottom bracket actually moved with the rear triangle.
    The Remedy is a cool bike but probably a bit much for what I need. I actually checked one out yesterday...beast of a bike.
    I'm considering the Reign because it feels pretty close in weight to a Trance but still climbs alright and it's a fair bit cheaper. The Mongoose seemed a bit heavier too but cheaper again.
    I might pick up a copy of that mag tomo and see what's what.
    MRO - I would probably push my spending if I could get a 1 for 2k but my local doesn't want to budget from the $2150 20% off sale price.
    Keven - Fox on the 2, Rockshox on the 1.
    E Subs, Sydney
    280
    If you don't have a subscription to Dirt, you might be waiting a while for the edition.
    Some of the same info in that artcicle here http://dirt.mpora.com/news/thursday-...bike-test.html
    Also, do some stats comparisons - the bottom bracket on the Teocali felt quite high - more like you were on the bike than in it.
    Nov 2009
    Cairns
    213
    Consider a 2nd hand reign? Get the same spec bike but for alot less. What size are you after as I have a mate wanting to part with his medium with (I could be wrong) full x9 spec for around $1500.
    Mar 2006
    toowoomba
    119
    Just a suggestion if you're open to other bikes, how about a 2011 Avanti torrent 2??? If you shop around you can get them for around the 2k mark. I think it would suit your needs, sought of between the trance and the reign, pedals well up hill and can handle the rough stuff going down.
    Specs:
    http://www.bikeexchange.com.au/bicyc...y/wa/100385770
    Review:
    http://andyandkatiearoundtheworld.bl...ke-review.html
    Jun 2010
    26
    my02 - everything you've said makes sense. I think I'll spring the extra for the Reign but I don't know if I'll stretch it all the way for a 1.The 1 definitely looks like its worth the extra $400 - $500 but I can't really justify the extra spend at the moment.
    Capt.Gumby - thanks for the offer but I'm going to buy new. I figure that the lifetime frame warranty means I can justify upgrading things as they break/wear out in the future.
    mason33 - the Torrent looks pretty much spot on for what I'd want (I think 150mm EDIT: OF THE REIGN might be a bit of overkill for what I need but the price is right) but the cheapest I can find a Torrent 2 in QLD is $2400 which is def out of my price range. Ideally it would be nice to pick up a 2011 something of that spec (brand isn't important) for 2K max like the Torrent you linked but I haven't been able to find anything.
    Jun 2010
    26
    A bit of a side note - I'm 5' 9" (maybe 5' 8.5") shorter legs, long torso and the Reign medium (17) seems ok but haven't been able to find anywhere to try a small (15). Does anyone know if I would definitely be a medium or should I try and locate a small to test?
