Results 1 to 10 of 12
Thread: 1x9; Is a chain guide necessary?
    Member asterix's Avatar
    Sep 2008
    Barossa Valley
    59
    Default 1x9; Is a chain guide necessary?
    Hi All,
    just after some advice on going 1x9. I'm building up a 1x9 29er & had assumed I'd need a chain guide like E13's. I'm looking at getting a Salsa 32 tooth chain ring & it mentions that it has raised teeth to prevent the chain from coming off. I'm just wondering if I have the Salsa ring will I need the E13 guide? Anyone else running 1x9 without a guide or with the Salsa ring? I'll be running it with a mid-cage XT derailuer if that makes any difference.
    Thanks
    3141
    3,766
    I have had a few OTB experiences from a dropped chain on a 1x9 or SS w/tensioner setup. Not fun. Get a 1X.
    Senior Member Moggio's Avatar
    Aug 2006
    Blue Mountains
    1,589
    Definately need a chainguide of some type. The MRP1.X have got cheaper nowdays and they work well and weigh very little. No point risking not having one.
    You can get by without one on a SS because your chainline is straight, on a 1x9 your chainline can be quite an angle. Also over bumpy stuff, with a rear deuralleur flapping around your tension can get pretty lose and the chain will just pop off.
    BMORC - Blue Mountains Off Road Cyclists
    www.bmorc.com
    https://www.facebook.com/BMORC/
    Blue Mountain Bikes Brooklyn/Lahar/Kowa/PO1NT Racing No Skid Marks's Avatar
    Jan 2004
    Australia
    10,320
    I'd run one.
    However, maybe the new clutch mechs will keep the chain on better if you don't ride that hardcore.
    ​CRANKINwww.crankin.net.au
    http://www.facebook.com/pages/Crankin/241698995840192
    Zerode http://www.zerode.co.nz/ .................................. Mozartt http://www.mozartt.com/
    Pinion http://pinion.eu/en/discover-pinion/pinion-p1-1....... Nicolai http://www.nicolai.net/
    Kowa http://www.kowa-ss.co.jp/mtb.html ...................... Shovel http://www.shovel.bike
    Canfield http://canfieldbrothers.com/ .............................. 77 Designz http://www.77designz.de
    Jun 2005
    392
    What about running a Widget chain ring?
    Support the formalisation of Bruce Ridge trails - Friends of Bruce Ridge - http://fobr.prophpbb.com
    Senior Member taquar's Avatar
    Nov 2009
    325
    Quote Originally Posted by Kramer View Post
    I've got one of those, a 28t, need to go bigger though.
    The older ones don't have a very strong guide plate, because i've bent mine alot, and then just bent it back with some pliers if I needed to. But I haven't dropped my chain since I got it, and I sorta plough. The new ones are supposed to be alot stronger, and you can get decent strength bash plates for it if you so desire.
    I personally think that it's brilliant, wouldn't go anything else, but alot of people like to have a bitch about them because they've never used them or think that the one they use is the best because they say so. Personal opinion. Not saying the other guides are crap, but I love the Widget.
    NOTE. THEY ARE NOT DESIGNED FOR DOWNHILL USE.
    moorey - "I accept the title of King of the Fuckwits."
    Senior Member flamin'trek's Avatar
    on the 'net, not the bike.
    815
    Quote Originally Posted by taquar View Post
    +1 for Widgit. No setup, no problems. Love mine, but I don't use it like a bash ring. Did have a bit of chain suck with mine in some really nasty conditions at last years DW100, but a quick stop and a little lube on the chain and right as rain again.
    Senior Member Nerf Herder's Avatar
    8,752
    The feedback that cSixx got from the PMB WCS was that the new Clutch mechs work great at stopping the chain de-rail from the bottom of the ring, but you still needed a top cage like these
    Csixx High Direct XC Guides
    cSixx ST XC Guide ... there is a high and low clamp in the ST model
    Pushie Enterprises: Find them on Facebook / PushieEnterprises and http://pushie.com.au/
    Oct 2007
    Sydney City
    2,465
    While I've been waiting for exactly those CSixx guides to touch down in Oz I've been riding chainguide-less.
    In the two weeks of riding my bike near to everyday I've dropped my chain once. 70% of the riding has been commuting, but there has still been plenty of stairs, bumps, etc and a little "proper" mtbing. I was using a pre-clutch 10 spd shimano xtr derailleur which proved to be flawless, but that snapped so it got replaced with a 10spd clutchless SLX derraileur and again it's been flawless.
    I'm using a blackspire 32t chainring, 11-36 XTR cassette and XTR chain. I will put a chainguide on, as this bike is meant to cop more abuse than I've been giving it recently. But with these clutch equipped derailleurs coming out I would definitely consider no chain guide on an xc bike.
    Quote Originally Posted by rabatt View Post
    nat for leader of the world!
    You heard it here first
    998
    Quote Originally Posted by Shredden View Post
    Hmm. Considering i can't ride my new awesome carbon 29er because of a chain slip incident on a road bike causing a broken collarbone, maybe i will install my Superstar XCR on this. But it looks so clean with no guide though!
    OP, this is exactly what you were after, but i can't test it yet!
