Page 1 of 10 123 ... LastLast
Results 1 to 10 of 92
Thread: 301 liteville
    Mar 2009
    209
    Default 301 liteville
    My new ride
    lyrik forks
    syntace wheels
    xo trail brakes
    Formerly Unfit
    Sep 2003
    Australia
    1,415
    Nice rig, big fan of these. What size frame? are you sticking with same wheelsize F+R?
    Quote Originally Posted by eddy1.7 View Post
    thanks guys for all the info, im still not sure what to get hahaha... does anyone know what sam hill rides?
    Mar 2009
    209
    Hey frame is XL and i run super short stem
    rides real nice
    26 wheels front and rear as they came from previous bike.
    Dec 2009
    51
    Awesome looking bike!
    Have you considered putting a corset air sleeve on the rear shock: http://vorsprungsuspension.com/produ...et-air-sleeve? I installed one on my 301 Mk 11 and it's transformed the ride - it really does feel like a coil shock now. I always found the stock Float CTD gave too much of an XC feel for a 160 mm bike.
    Llama calmer mitchy_'s Avatar
    4,589
    i thought the XL and XXL were supposed to use 27.5 and/or 29" wheels?
    sweet ride though, have always loved the look of the 301.
    Mar 2009
    209
    Hey mitchy they are but i purchased the frame on its own put my gear on .
    runningsingle wall 2.5 tyres front and rear ,lots of room and they are similar size Dia to 650 b
    Corset, will look into that , running fairly soft set up atm
    so far I am super stoked ,forward geo bias, coming from a single pivot bikes ( Santa Cruz bullet, craft works )
    rides well
    Senior Member DeBloot's Avatar
    State of Confusion
    973
    Quote Originally Posted by ...G... View Post
    That's interesting
    When you say XC feel, what do you mean
    I've had my shock custom tuned, but it just never quite feels like a 160mm travel shock should
    I actually find it good OK rock gardens, but a bit harsh on landings to flat
    Has the corset only improved the small bumps, or better overall
    I'm seriously considering this upgrade or the Evol
    Senior Member crank1979's Avatar
    Bargo
    2,082
    I run a RS Monarch Plus on mine and it's great.
    My bikes
    IMBA Au member #84
    IMBA member #157036
    Wollondilly Trailblazers MTB Club
    canberra
    574
    Sweet! another 301 in full flight mode :)
    This is curious - I've only just fitted a bigger volume spacer in mine. I didn't really have an issue with how the shock worked, but wanted a bit more ramp up right at the end, which is what I got. Took it for a lash at Stromlo and was pretty happy with the result.
    Although - the corset is meant to help offer a little more stroke support.. well, now that could be interesting....
    Dec 2009
    51
    Quote Originally Posted by DeBloot View Post
    That's interesting
    The standard Float CTD worked reasonably well. It always used full travel, and I can not recall it ever giving a harsh bottom-out feel.
    However, when travelling at a reasonable pace over rough ground I felt that the ride was a bit 'chattery', a bit too firm for a 160mm bike. That's what I meant by "XC feel".
    The Corset air sleeve has improved small bump compliance but, in my view, that's not the biggest improvement with the Liteville. The bike now feels more planted and plush at speed over rough ground; that's the change I've really noticed.
