Results 1 to 7 of 7
Thread: How to build DH/freeride jumps?
    Senior Member trouble's Avatar
    Jul 2005
    Chatswood
    1,237
    Arrow How to build DH/freeride jumps?
    Hey everyone,I've searched but still haven't seen what I am looking for. I am looking at building some downhill/freeride jumps decently large. Some good examples of these are from this video,
    http://www.youtube.com/watch?v=gloeXuBQFPY
    I'm just wondering cause I've seen some which have nothing under them,as if they used plywood with dirt ontop with logs on the side?
    Oppinions, help is greatly appreciated,thanks,BEn
    .:The PHP Campaign:.
    Picture House Productions
    PROWD OWNER OF THE ORIGINAL SUNDAY>IRONHORSE
    Senior Member thompo's Avatar
    Nov 2006
    deadlands, bris.
    980
    well heres your DH
    http://forums.farkin.net/showthread....ild+dirt+jumps
    and here is your DJ
    (might help if you search on farkin using words such as how to's + what you want, although common words aren't included)
    Senior Member pinned--->'s Avatar
    Jun 2007
    Holding my pope.
    2,403
    For most of ours we find two tree's and put a door behind them and just pile dirt infront of the door, And for the downramp just make a massive pile of dirt and compact it down the way you want it.
    flickr
    JAMES GEMMEL <3 <3 !!!
    Member LyonsDJmetalheaD's Avatar
    Jan 2007
    Victoria
    82
    Quote Originally Posted by trouble View Post
    Best DH/Freeride video i have seen in my life so far.
    And I have seen Roam and most NWD.
    My advice is to keep the the track flowing.
    Make sure you have time to posistion yourself before and after landing then start to gain more speed.
    Momentum is a key factor. You want to gain momentum and keep it flowing.
    No abrupt turns after jumping.
    Support the Defence Forces.
    Stack count 10/3/07 to present : 5
    Senior Member Stack Shack's Avatar
    242
    I make my downhill jumps really mellow (sp?). Not to steep with a long down ramp. once i get the camera working ill post some pis. Also, how steep is this track. If possible post pics
    Quote Originally Posted by Rhianna View Post
    Bocaj loves my potatoes, reckons they're better than mums.
    Senior Member CGR's Avatar
    Adelaide
    330
    Quote Originally Posted by Stack Shack View Post
    ^^^^That would probably be the best idea.
    The angle/curve and size of the kicker is almost completely dependant on the speed of the run in and the size of the chosen area (rider skill is another factor, but thats really up to you). For example: if the site of the jump has a lot of speed coming into it, its best to make the slope of the kicker a very gradual one. If the kicker is too steep for the speed your likely to be bucked off the bike, which is going to hurt when you come down. As you would expect, a gradual kicker will give you less air time and probably more distance, than a jump with a steep kicker which gives you the opposite effect.
    The size of the area gives an indication of the size of the jump i.e. a large jump needs a large area, because your going to be going further and building bigger. Freeride/downhill jumps are usually aimed at distance over height, where dirt jumps (as in trails) are usually designed for height for tricks.
    The down ramp is simple: long and gradual (this give you a good margin for miscalculations...). It will pretty much work for any kind of kicker (unless you building some kind of freeride pump-track... ).
    A very important thing to keep in mind if they are being built on a DH track (and/or are going to be under heavy use) is how they will fare over time, will they wear down quickly? are you prepaired to maintain them? etc.
    As you pointed out, the jumps in the video are simply a box of wood, that is filled with dirt, for both the kicker and the landing. This just means they didn't have enough dirt in the area to make a completly dirt landing or thought that having the box would make it quicker and last longer. The catch to the wooden box (and wooden landings in general) is the cost of the wood and any other materials needed. But if you can afford it, its a great way to save time, and dirt. NSMB has a shitload of examples of this (go into the photo gallary section).
    Most of it seems like common sense and its longer than originally intended, but i hope it all helps anyway.
    Member simon rocks's Avatar
    Jun 2007
    89
    wheres that track at, its awesome.
