A fatter headtube means more surface area to weld the top and down tubes to, which means stronger I guess. This also allows for different shaped and supposedly optimised tubing ... to reduce weight and increase strength.
A tapered headtube tries to compensate or compromise weight versus strength. So it allows for a tapered steerer and increased weld surface area for the down tube ... but reduces the associated weight at the top end.
The problem with tapered is that its again none standard with several cup sizes at the bottom eg the 2009 glory has a 49mm bottom cup (from memory) whilst the 2010/2011 has a 56mm bottom cup ... other brands have a 46 or 48mm
Whats the build Haggle King ??? heavy trail, or Light FR
