NSW 12mm Rear Axle FOUND
camzh
Item: 12mm Rear axle. To suit 135mm hub with thick dropouts (9mm)
Item Condition: not fussy
Reason for wanting: The donor bike wants its axle back.
Extra Info: This is to suit an older Transition Blindside with 12mm dropouts. The dropouts are not threaded so I need a bolt and nut type arrangement.
The drop outs are 9mm thick (each) and I am currently running a Syntace 135mm+ axle from a 2011 Norco Range using the 'nut' from the frame. (the Norco runs a 142mm x 12mm rear)
気が狂っている男
I have a 135x something axle. Came with an azonic hub a little while ago. It should meet your needs.
I also have a 150x12mm that may be narrow enough to use as you are doing with the norco axle.
