Okey dokey, having spent a large chunk of the day out on the course I noted a few riders climbing the steep fire trail back to the laser observatory, which is not right. At the firetrail intersection you take the right fork and head right out to Stromlo Rd. If you don't see a new shed being built and Stromlo Rd, you've got it wrong
(see the first image)
Just before you get to the sheds turn left and then left again to stay under the powerlines;
(images 2 - 6)
I was lucky enough to have a hand today (big thanks Pat!) and as a result the new section of trail past the laser observatory is roughly cut in (thanks to ANU for allowing this!). When you go past the Visitors Center (to the right, uphill) you come to a gate. From there riders were set to use the tar to get back to the Echidna firetrail but ANU have allowed us to cut in a track for this event. Immediately before the gate there is a red arrow pointing left, head past the wattle tree and hopefully the line is well enough defined. Stay high from the gum tree and track direct to the observatory (you should see a largish rock, that is your aim point). When you hit the car park skirt around its left edge and aim for the tall dead tree. The trail will be self evident. Remember that the laser observatory is in use so PLEASE stick to the car park as they may be using the laser target downhill from it; and don't freak if you see a green laser, that's what the observatory does! Car park safe, downhill area not.
(images 9-10)
We have also moved the cross over to Echidna Junction proper. On the first pass (orange) you head down the firetrail from the old DH start and into the single trail to Echinda Junction then onto Western Wedgetail. On the second pass (red) from the laser observatory you now stay on the firetrail up past the grave-site turnoff and then ride off to the right of the gate and into Echidna. The off to Rollercoaster and big grins. The last image explains.
Hopefully all that makes sense. I have stuck out a couple of red arrows to help, we can't stick out too many until the event proper. Any questions then PM me or drop it on this list
Cheers!
Mullet
