Item: 2014 Specialized Stumpjumper FSR Expert Evo Medium
Item Condition: As new! Not a mark on it!
Reason for selling: Project and honeymoon
Price and price conditions: $4999 Willing to ship at buyers expense but would prefer local pick-up
Extra Info: Only 5 months old and used pretty sparingly as i've been too busy to ride much (got out once last month!). Selling to put some money into a project and hopefully some into a honeymoon! It's as mint as a used bike will get. Even the tyres barely show any sign of use.
Details:
FRAME: Medium
REAR: SHOCK Custom FOX Float CTD Factory w/ AUTOSAG and Boost Valve, Kashima coating, Climb, Trail, Descend settings and reb adj., 195x51mm
FORK: RockShox Pike RC, Solo Air spring, tapered alloy steerer, comp, lockout, and reb adj., 15mm thru-axle, 150mm travel
STEM: Specialized Trail, 6061 alloy, 4-bolt, 6-degree rise, 31.8mm clamp
HANDLEBARS: Specialized All-Mountain, low-rise, 7050 alloy, 750mm wide, 8-degree backsweep, 6-degree upsweep, 31.8mm
GRIPS: Specialized Sip Grip, light lock-on, half-waffle aramid-infused
FRONT BRAKE: Custom Avid Elixir 7 Trail, 4-piston caliper, steel backed metallic pad, 180mm
REAR BRAKE: Custom Avid Elixir 7 Trail, 4-piston caliper, steel backed metallic pad, 160mm
BRAKE LEVERS Custom Avid Elixir 7 Trail, hydraulic disc, tool-less reach adj.
FRONT DERAILLEUR: No
REAR DERAILLEUR: SRAM X01, 11-speed, mid cage
SHIFT LEVERS: SRAM X01, 11-speed, trigger
CASSETTE: SRAM X01, 11-speed, 10-42
CHAIN: SRAM, 11-speed, hollow plates/pins, PowerLink
CRANKSET: Custom SRAM carbon S-2200, custom XX1 style ring, PF30 spindle, removable spider, 175mm
BOTTOM BRACKET SRAM PF30, OS press-in bearings, sealed cartridge
PEDALS: No
RIMS: Roval Traverse, alloy disc, 24mm internal width, 27h/32h
FRONT HUB: Roval Traverse, 15mm thru-axle end caps, 27h
REAR HUB: Roval Traverse 142+, XX1 driver body, 12mm thru-axle, 32h
SPOKES: DT Swiss Super Comp, 2.0/1.65/1.8 stainless
FRONT TYRE: Specialized Butcher Control, 2Bliss Ready, 26x2.3", foldable aramid bead, 60TPI
REAR TYRE: Specialized Purgatory Control, 2Bliss Ready, 26x2.3", foldable aramid bead, dual-compound, 60 TPI
INNER TUBES: NO - Set up Tubeless
SADDLE: Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST: Specialized Command Post IR, 3-position, internally routed adjustable height w/ air spring, remote operated, single bolt head, 30.9mm, 125mm travel
SEAT BINDER: 7050 hard anodized alloy, single bolt, 34.9mm
Any questions pm or text me 0401 303 608
Pictures: Yes
Details:
FRAME: Medium
PEDALS: No
Pictures: Yes
