Item: 2015 Specialized Enduro Expert Carbon 29 - Size Medium in White
Item Condition: Excellent - presents as new
Reason for selling: N-1, Just not enough saddle time
Hi-Res photos available on request
Extra Info: The cage carries a SWAT bottle with CO2, Tube and tool (not shown). Chainbreaker is mounted in the headstem.
Specifications: FRAME FACT IS-X 11m carbon, 29" geometry, FACT IS construction, FACT carbon front triangle, M5 alloy rear triangle, tapered headtube, PF30 BB, internal Command Post IR routing, 142mm dropouts, full cartridge bearing pivots, replaceable derailleur hanger, 155mm travel
REAR SHOCK Upgraded Cane Creek DB AIR Inline, high/low-speed compression and rebound adj., w/ climb switch, 8.5"x2.25"
FORK RockShox Pike RC 29, Solo Air spring, tapered alloy steerer, w/ lockout, compression, rebound adj., 15mm thru-axle, 160mm travel
HEADSET 1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STEM Specialized XC, 3D forged alloy, 4-bolt, 6-degree rise
HANDLEBARS Specialized XC, mini rise, 7050 alloy, 8-backsweep, 6-upsweep, 10mm rise, 31.8mm GRIPS Specialized, light lock-on
FRONT BRAKE SRAM Guide RS, metalic pads, Guide R caliper, 200mm Centerline rotor REAR BRAKE SRAM Guide RS, metalic pads, Guide R caliper, 180mm Centerline rotor BRAKE LEVERS SRAM Guide R, alloy lever, w/ reach adjust
REAR DERAILLEUR SRAM X01, 11-speed, carbon cage
SHIFT LEVERS SRAM X1, 11-speed, trigger
CASSETTE SRAM X01, 11-speed, 10-42
CRANKSET Custom SRAM S-2200, carbon, PF30 spindle, 30T, 94mm BCD spider
RIMS Roval Traverse Fattie 29, alloy disc, 29mm inner width, 24/28h
FRONT HUB Roval Traverse, 15mm thru-axle end caps, 24h
REAR HUB Roval Traverse 142+, XX1 driver body, 12mm thru-axle, 28h
SPOKES DT Swiss Revolution
SADDLE Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
SEATPOST Command Post IR, Height adjustable, alien head design, bottom mount cable routing, w/ remote adjust SRL, 30.9mm, 125mm travel
Pictures:
Pictures:
