Z
Zaf
Guest
Removed by user
#pleblife!I don't upgrade or change for the sake of it!
And Tubbsy - I've got the tool now. We will share it.Looks like a good option.
Anybody know the intervals they recommend for bearing replacement?
Hey thanks!And Tubbsy - I've got the tool now. We will share it.
WTF! Hows that belt drive working out for you? Upgraded your Selva yet?Just buy quality in the first instance and you won't have an avenue to upgrade.
What fork do you have? With Fox forks (and probably most others) you can generally just swap the CSU if desired.Fork offset has changed, so I'd need a new fork too which makes it pricey.
What's available in 44 offset that can be set to both 130 or 140?
I’ve got a 34 Factory from 2017.What fork do you have? With Fox forks (and probably most others) you can generally just swap the CSU if desired.
