Item: 2019 Specialized Evo Epic Comp 29 - Medium
Item Condition: As New (Literally)
Reason for selling: Plans changed
Price and price conditions: $OLD thanks for looking
(including complete MTB XC SWAT Kit from Specialized and Shimano XTR pedals (Used))
Extra Info: This bike is literally all but new and will not disappoint .
Bike has had a home in my shed for a few months but apart from some bike path use has not seen any trail action.
Riding plans changed soon after purchase and this fantastic bike is in search of a home on the range where it can roam a little further a field.
Any questions welcomed.
Specification:
CHAIN SRAM NX Eagle, 12-speed
BOTTOM BRACKET SRAM DUB, threaded BB
CRANKSET Truvativ STYLO, DUB
SHIFT LEVERS Sram NX Eagle, trigger, 12-speed
CASSETTE SRAM NX Eagle, 12-speed, 11-50t
CHAINRINGS SRAM Eagle, 32T
REAR DERAILLEUR SRAM NX Eagle, 12-speed
FORK RockShox Reba RL 29, Motion Control damper, 42mm offset, 15x110mm thru-axle, 120mm of travel
REAR SHOCK Custom RockShox Micro Brain shock w/ Spike Valve, AUTOSAG, 51x257mm
SADDLE Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
SEAT BINDER Alloy, 34.9mm
SEATPOST X-Fusion manic, 30.9mm, (125mm)
HANDLEBARS Specialized Alloy Minirise, 10mm rise, 750mm, 31.8mm clamp
GRIPS Specialized Sip Grip, half-waffle, regular thickness
STEM Specialized XC, 3D-forged alloy, 4-bolt, 6-degree rise
FRONT HUB Specialized, sealed cartridge bearings, 15x110mm spacing, 28h
REAR HUB Specialized, sealed cartridge bearings, 12x148mm thru-axle, 28h
INNER TUBES Set-up tubeless
SPOKES DT Swiss Industry
RIMS Roval Control Alloy 29", 25mm internal width
FRONT TIRE Ground Control, GRIPTON® compound, 60 TPI, 2Bliss Ready, 29x2.3"
REAR TIRE Fast Trak, GRID casing, GRIPTON® compound, 60 TPI, 2Bliss Ready, 29x2.3"
FRONT BRAKE SRAM Level TL, hydraulic disc
REAR BRAKE SRAM Level TL, hydraulic disc
PEDALS Shimano XTR
FRAME Specialized M5 Aluminum w/ D'Aluisio Smartweld Technology, threaded BB, 12x148mm rear spacing, internal cable routing, 100mm of travel
Specification:
PEDALS Shimano XTR
