VIC 26 forks
merc-blue
Item: looking for a 26er fork
Price range/Willing to Pay: Depends on fork probably a max of $300
Extra Info:
Doesn't matter if it needs servicing or abit of fixing, will even consider "parts"forks as I have alt of parts and may be able to use your parts with my parts to make a fork.
Looking for a 26er fork with a 1 1/8 steerer, and preferably a 20mm axle, will consider 15mm.
No marzocchis
I'm not sure if these will do? Bomber air 55s. they need a rebuild. 195mm steerer 1-1/8. 20mm. I think they're 150mm though. I'll swap you for those pikes assuming they still work? I was going to get the 55s rebuilt but haven't had the time...
Sorry Merc. I didn't read it properly that the lockout doesn't work. I'll get around to getting these rebuilt then..
I have a set of 2014 DJ1 forks, can't remember if they are 100mm or 120mm. They are basically new (hardly used 5 times)
Let me know if this suits
EDIT: Sorry these are tapered so probably won't suit
...So i'm not up for grass cutting, but if these are 120mm I might be interested. any idea on the weight? I shall wait politely in line.
Bupton.
I need straight steerer. That said if your splitting your bike i would love your bars and stem and maybe post and saddle if your selling them
Bupton.
Yes sadly I think I will be splitting the lot, ill send you a message a bit later on
I have a coil pike 140 to 95mm u turn 20mm axle. Just been serviced by summit cycles. Not been on the bike since. Came off this.
. $200.
