The Lenz has a Dorado - full length USD fork, but travel reduced to 7".
It definitely will NOT work with a boxxer, you'd need way more tyre clearance than that.
There is a picture floating around on the net of a Fox 40 "modified" to fit 29ers.
I can't find it at the moment, but I found this picture of a 36 with the same mod...
CAUTION: VIEWING THE FOLLOWING PICTURE COULD CAUSE YOUR TOE NAILS TO CURL UP!
you have been warned:
Now keep in mind that the Fox 40 already has gigantic tyre clearance.
There are a few real, dedicated 29er DH forks, all somewhat questionable. I highly suspect that 8" of well tuned suspension and 26" wheel will do better in the rough than 6 or 7" of dodgy suspension and a bigger wheel.
