Trying to help a friend out with a busted wheel, he has a tight budget and needs the following below to get him out on the trails.
Item: 29er 142x12mm rear wheel 6 bolt rotor design and Sram XD freehub. Sealed bearing hub.
Item Condition: Must not be beaten. A slight tru or tension is ok. Bearings are ok to replace if needed.
Price and price conditions: $200 including postage MAX BUDGET.
Extra Info:
Must be 25mm or wider rim.
29inch rim
Tubleless compatible
6 bolt rotor hub
Sealed bearing
XD free hub
32h spoke rim ideally.
142x12mm rear hub
Black prefered.
Pictures: Will be required.
Thanks
Extra Info:
29inch rim
6 bolt rotor hub
Sealed bearing
XD free hub
142x12mm rear hub
Black prefered.
Thanks
