I started with flat bars on mine and didnt like them, changed to Crank Bros Carbon risers, they suit me much better.I have noticed that manufacturers of 29er bikes have in their technical info stated that flat bars are 29er specific. Does anyone know the reason for this?
Why are flat bars better on a 29er than riser bars? Is it something to do with the effective handlebar height?
Discuss.
Yep.Its purely personal preference I believe.
+1Having said that, I run standard 580mm flat bars on my bike and don't appear to have trouble negotiating corners. Theory be damned, I say - just do what suits you.
I raced for a year on my SS 29er (it's currently doing time as a touring bike) with 580mm bars and loved it. Wide bars may provide leverage for SS but they're not required if you like to spin.Got a set of Titec J-Bars on my SS 29er. Works well for SS application giving heaps of leverage at 700mm wide and doesnt feel wide (till you met some tight trees)
Lizard Skin Charger grips are very nice too. They dampen vibration like Oury grips without being as chunky.what about grip choices for your bars, i like oury,s + am thinking of trying flat bars , found since converting from a 5 inch bike to a 100mm hardtail ,ourys are the only grips that are comfy enough with the xtra shock i seemed to be gettin through the bars with the shorter travel
Was interested in a set of these.
Pretty sure Dirtworks distribute ESI grips in Australia. Will cost you much less than $60 from your LBS...Was interested in a set of these.
Pity they make the most out of postage, which means your $15 grips end up costing closer to $60
Worthwhile if you really like them, but I have an aversion to profiteering through postage
Instead purchased some JETBLACK foam grips from LBS for $18. (which they fitted for me while I waited at no cost)
Roland
