silentbutdeadly
has some good things to say
We'll be here. Hopefully with a slightly longer and more diverse lap too. A bit of change in the track regardless...Cheers, hopefully I'm back to do the coomie 3H this year.
Awesome ! Its a strange race... so fast I dont even carry spares.We'll be here. Hopefully with a slightly longer and more diverse lap too. A bit of change in the track regardless...
Ops... one of your sponsors.I don't understand the Schwalbe bashing.
Both hands in air... got me there.Burt had tons of grip even when the rain came in sideways and Billy was busy shaking stans
I do. I hated RR and NN after suffering casing and tread fails in the mid spec range...which still aren't cheap. So switched to Geax and have had no dramas except finding that the TNT casings don't like big blokes on low pressures...nothing a little more air and a lot more finesse won't fix.I don't understand the Schwalbe bashing.
I wear out the tread in mine.
The side knobs have had some reinforcing lately.
My RaRa and Burt combo from the 24 still look new.....
I could never understand it either after ~18,000km on Schwalbe. Then I had a Racing Ralph which wouldn't bead, and then the three after that lasted <100km before they were dead with sidewall slashes. I always felt if I could get them to the 300km mark, after that they would have no trouble with sidewalls. I dunno if the crap ones die early, or if the sidewalls loosen up and become more compliant and less likely to slice.I don't understand the Schwalbe bashing.
I've had several Maxxis Ikon EXO sidewalls fail (rear) whilst at the same time having no RR snakeskin tyre failures (front) on two bikes for the last 3 or so years. Probably not a fair test as the rear may be more prone to poor line selection and has more weight on it. Still, in the hand the RR snakeskin sidewall feels more robust than the Ikon EXO.I could never understand it either after ~18,000km on Schwalbe. Then I had a Racing Ralph which wouldn't bead, and then the three after that lasted <100km before they were dead with sidewall slashes. I always felt if I could get them to the 300km mark, after that they would have no trouble with sidewalls. I dunno if the crap ones die early, or if the sidewalls loosen up and become more compliant and less likely to slice.
Now trying some Maxxis Ikons and the sidewall is pretty tough in comparison. Better grip in the corners, worse under braking. Pretty heavy though....
I'm a big purgatory fan. I'll be sticking that and probably a butcher on my Honzo.I'm running a Purgatory 2.3 front and back now. It's the best traction I've had on the slippery clay we get west of Melbourne.
