TAS 30.9 Seatpost (Zero-Offset)
Isaakk
Item: 30.9mm zero offset seatpost
Item Condition: Cheap. So long as it is black, zero offset, and holds a seat i'm happy.
Price and price conditions: Length doesn't matter. If it's 60mm long, that's long enough.
Item: 120mm travel 29er fork, 180mm+ steerer
Item Condition: Functional & looked after
Price and price conditions: up to $700ish (or possibly more depending on fork)
Extra: Ideally looking for a 34 StepCast or 2021 35mm SID or similar. Was going to buy new but they're all out of stock?
Bought SID Select brand new
creaky
The obviative
Factory 34 10 rides old, been sitting in a box since late last year as I ended up buying a new bike just after getting the fork. I did a lowers service and took photos of the stanchions (unmarked) before packing it away.
Currently setup 130mm but I’ve got a feeling I’ve got a 120mm airshaft for it but would need to check.
Slightly less than 170mm though as per photo:
363955
Isaakk
Hmm, probably too short unfortunately. Took some measurements and is 130mm headtube with IS42/IS52 headset, allowing an extra 40mm or so for stem/spacers. I think that actually puts minimum required at around 178mm or more so had better update post. Keen on the post if it's 0-offset Contact SL or similar.
