Bloody disappointing. Has your frame made it back there yet?The Machines still have a similar failure rate not quite as bad I think. Again the bonding issue even with the screws.
It's meant to arrive there today. So I will start hassling Leo at the end of the week.Bloody disappointing. Has your frame made it back there yet?
You should email that to Leo. I’m sure he’d love unsolicited enginerding adviceTo my mind, changing the crappy bonded single lap-joint to a bonded tongue-in-groove/double lap-joint would probably remedy this issue (or at least make it a lot less likely). The CNC "tubes" are going to twist and distort under load, and there's no mechanical assistance to the bonding in the single lap joint used by Pole, so if the bonding has any flaws it'll just spread each as it loads and unloads in use (which with the cyclical nature of cycling, isn't going to be an ideal match...).
"Dear fuckhead..."You should email that to Leo. I’m sure he’d love unsolicited enginerding advice
"Hey baby, how 'bout a triple riveted zigzag lap joint?"You had me at "lap joint"
Great name for a strip club.
Prep step 1: Take customer's money.I wonder what sort of prep process they are using on the aluminium before they do the actual bonding and whether it is having any impact on the failure?
Leo told me he was going to increase the wall thickness and give it more bridging on join.To my mind, changing the crappy bonded single lap-joint to a bonded tongue-in-groove/double lap-joint would probably remedy this issue (or at least make it a lot less likely). The CNC "tubes" are going to twist and distort under load, and there's no mechanical assistance to the bonding in the single lap joint used by Pole, so if the bonding has any flaws it'll just spread each as it loads and unloads in use (which with the cyclical nature of cycling, isn't going to be an ideal match...).
Fingers crossed this is true for your sake.Leo told me he was going to increase the wall thickness and give it more bridging on join.
Apparently the revised CADs for the CNC works will completed today. Surely changes to the design would have to through engineering, testing (both on paper and real world) first.
Have they ever explained how they tested their concept? I like the way the Kavenz guys were completely transparent about failures on the test rig:Leo told me he was going to increase the wall thickness and give it more bridging on join.
Nothing like this but he claims to have some videos that he hasn't posted yet. Wonder what they reasoning behind that is. The frame gets split in two by putting a bar through the headtube and twisting. Apparently 500kg of force is needed to seperate 30mm of bonded aluminium.Have they ever explained how they tested their concept? I like the way the Kavenz guys were completely transparent about failures on the test rig:
?? Deemed it....?Apparently could not see what I was on about and has deemed everything .
Edited now. *perfectly fine?? Deemed it....?
