Unsubscribedand the frame to get back from the powdercoater
I approached transition direct when I had my bottlerocket. Wouldn’t send decals, but they sent me the files....Does look good. See if you can get some Transition decals from @xero or Transition direct in the spearmint green they used to use on the Double and Trail or Park:
hahah yeh the budget flew straight out the fkn window when almost none of the parts from the Norco fit this and I decided I didn't want a half-assed bike. Don't tell my girlfriend how much I've spent on this thing or I'll be sleeping with it on the street. The decals are the cheapest part of this bike at $15 a set I can manage a few setsEngages in budget build...blows coins on different coloured stickers...I'm confused.
More cash to blow on gnarly parts dude!!!
Paint looks good. Like how this is coming together. Looking forward to seeing it finished!
Well I'm at about 5k so far so it's a good start I think, like I said I'm not trying to be homeless hahahShould have just spent the cash up front ..
Bike life is the good life. Live in a tent at the trails!Well I'm at about 5k so far so it's a good start I think, like I said I'm not trying to be homeless hahah
Sweet thanks for the heads-up. I just pulled out the tan inserts just to see how much play is there if I re-use the metal ones and yeah it's def a no-go. The kit you posted looks like what I need. Might hit up some local shops to see if they have in stock or if not if they can set me up with the right width like @pink poodle mentioned. @pink the shock should be cool in that position as it's the stock position, but I have also seen people run them backwards.Looks sweet!
You'll need new reducers. Those poly bushes work with the newer 5 or 7 piece reducer set rather than the metal "top hat" reducers that work with the metal pressed DU bushes of old.
https://www.mtbdirect.com.au/fox-shox-7-piece-rear-shock-mounting-reducer-kit
I was under the impression those poly bushes were the latest and greatest in bushing tech?Possibly remove the poly bushes and replace with a standard DU Bushing... you will have to size check though.
Rockshox / FOX DU eyelet bushing (Pair) 1/2" x 1/2"
Genuine Rockshox / FOX DU eyelet bushings (pair). Sits inside the eyelets of ALL FOX rear shocks using the 3-piece mounting hardware system, and all Rockshox rear shocks 2008 onwards. Teflon lined. If you have movement coming from the shock mountings, then this is more than likely the culprit...cyclinic.com.au
All good bikes run double 22x8. I’ll possible have a spare set if stuck.8x22mm is very common still so you shouldn't have any problems getting some locally if you've got a decent shop to hand.
