Some compression plugs just aren't that good and will slip even with carbon paste etc. Especiall the ones that have multiple segments across the legngth. A steerer tube that has an out of round internal surface doesn't help.Welll, bugger, things not as hunky dory as first expected. After my maiden commute on the fork, 25km each way, by the time I got home there was a knockin' and a rockin' in the setup.
Did the usual things, expecting that everything had just settled in, but the the quick nip up of the top cap didn't resovle the issue. The expansion plug just wasn't holding in the steerer tube, even up to 8nm tightening. Did a full disassemble of it, all looks good, then figured I'd try another I had on hand from the previous fork, a circa 2010 Neco expander.
Hmmmm, the Neco doesn't want to go in. the lip of the lower compression nut is catching on something. Stick my finger in the fork and have a feel around, hmmm, no wonder the other compression plug wasn't holding, there's 3 prominent ridges/lips of carbon left over from the moulding, running vertically all the way down the steerer length. Hard to see in the photos, but they do indeed go all the way down as far as I can see. Thankfully they're 100% not cracks, but certainly a quick finishing process was done.
Currently in messaging with the Ali seller to see what their thoughts are before I try to get a tube of some fine grint sandpaper in there. If that's what has to happen, I'll be OK with that, but I'm interested to see their thoughts first.
View attachment 412245 View attachment 412246 View attachment 412247
Delic Bike Store is always a good option, albeit not an AliChoice vendor so freight becomes a factor. But the pricing ends up much the same usually. The other one I've used to good effect is OK Bike Store.What's the go to Aliexpress shop for legit Shimano drivetrain parts at the moment?
If price reasonable going to ditch my SRAM GX lever and derailleur to XT 12 speed. Will leave the chain / cassette / front chainring for the time being unless the Aliexpress deal is too good to pass up (bit too lazy to change freehub)
You may not need to ditch your shifter unless, you really don't like it. I'm running the original Eagle X0 shifter on my Ripmo, along with M7100 derailleur, and X01 cassette, with zero issues.
The steerer tube was slightly out of round internally, but getting everything nice and smooth has meant good compression all around and no issues with holding.Some compression plugs just aren't that good and will slip even with carbon paste etc. Especiall the ones that have multiple segments across the legngth. A steerer tube that has an out of round internal surface doesn't help.
From your previous photo, I'd also make sure that your compression plug is long enough to extend all one way down to your stem lower bolt so that the entire tube is supported
Bought another branded T-Mac copy (and some longer pins). The previous ones have been excellent.
Just found this amazing item on AliExpress. Check it out!
AU$1.70 | 50pcs M2 M2.5 M3 M4 M5 M6 M8 DIN916 304 Stainless Steel Black Grade 12.9 Hex Hexagon Socket Cup Point Set Screw Grub Bolt
5/10/50pcs M1.6 M2 M2.5 M3 M4 M5 M6 M8 M10 M12 DIN916 Allen Hex Socket Cup Point Set Screw Grub Bolt 304 Stainless Steel Black - AliExpress 13
Smarter Shopping, Better Living! Aliexpress.coma.aliexpress.com
AU$67.15 | GOLDIX Ultralight 3 Bearing Pedal Waterproof Dustproof Antiskid CNC Pedal for MTB ROAD Bike Folding Bike Big Pedal
GOLDIX Ultralight 3 Bearing Pedal Waterproof Dustproof Antiskid CNC Pedal for MTB ROAD Bike Folding Bike Big Pedal - AliExpress 18
View attachment 412306View attachment 412307View attachment 412308
Nothing a bit of heat won't sort out!263? Wow you really don't want them to come out do you!
Off topic, but is there a chart for loctite? I have no idea what does what. Why are there so many?!
Definitely, usually my go to.Then we all just use 243 for most things.
I've used the red one long ago on a place that I shouldn't have. Utter hell to remove it from chain ring bolts. One for the F*wits thread !Definitely, usually my go to.
Unless of course the first one I grab (in this case) is the red shit.
ok, only going to buy red ones from hereon lol.I've used the red one long ago on a place that I shouldn't have. Utter hell to remove it
Red is likely to bring out the BFO wrench, heat gun and harsh language faster.ok, only going to buy red ones from hereon lol.
Any Ali shop recommendations for
- bike bags (top tube, burrito bag etc)
- tubeless valves
- TPU tubes
