Even though it is November, Melbourne is still far from consistent Spring weather just yet. Nonetheless it was time for some post-Winter love for the rig!
- Fitted Enduro MAX suspension bearings.
- Monarch shock air can service with new seals.
- Serviced pedals.
- Pike lowers service with SKF green low friction wiper seals, and Fox Gold oil.
- New brakes! Hope Tech 3 E4
Maestro bearing press kit makes it a walk in the park. No fudging around with socket sets and vice. For the 2015 onwards Reign I had to exchange some of the dies around and add a washer to improv, but it did the job just fine.
SKF seals next to stock seals. Stack height is a bit more but once you have your ideal PSI sorted out, it's no big deal that the sag indicators are a bit off.
They feel amazing...
Had to Dremel a bit out of the Avid brake adapter, so that the new calipers would clear.
Very happy with the Hopes. The Saints are amazing brakes but I found they just dumped on the power too hard at first (servowave). The Hopes are more linear and ramp up in power as you pull the levers in more, which is really the way it should be. Plus the heavy spring action return on the lever feels great.
