MARKL
I agree with you up to a point. In some ways it is unrealistic but it is also a situation created almost entirely by the bike manufacturers - who needs 50+ effing headset standards and I have given up trying to understand bottom brackets but as I said this is a situation created by the bike manufacturers. If I go to a specialist dealer for a particular brand, knowing that I will pay a premium, is it unreasonable to expect they can get me going? If they can't most peoples experience is that it is quicker to order over the net than to stuff about with the LBS deciding when they feel like ordering from the local distro (which is generally the longer part of the waiting period). I do think there are practical ways around this - LBS orders part and has it delivered to your house instead of the LBS if you want to fit it yourself(it is just an address on an express post envelope at the end of the day). Having the most common spring sizes/weights is not unreasonable (most shocks under 8.5 long are now air anyhow) so realistically you are looking at 8.5/8.75/9.5/10.5 in and 350 -500 pound weight range - so 4 lengths by say 7 weights at the most. Again I agree that consumable items have been made such a huge pain in the arse by the proliferation of standards.So you tried to buy largely bike/application specific consumable small parts and were surprised your local shop didn't have springs in 25lb/in increments from 150lb/in to 850lb/in and beyond in every stroke length from 6.5x1.25" to 9.5x3.0" in 2 different diameters, steel and ti? Reducers which come in quite a wide variety of sizes, are costly and rarely sold?Tubeless valves for every rim/rimtape/sealant combo? A BB which could come in two different tapers, about four different splines, E-type, Standard, and a wide range of axle and shell widths for each combo? You cannot expect every LBS to have THAT kind of stock holding. You're in mainland Australia, anything in stock at a distributor should be available in your shop ~24-36 hours from the point they order.
