Nautonier
I was attempting to bleed the levers on my Avid X0 Trails yesterday and had massive problems with huge runs of air bubbles coming into the syringe while I was at the 'creating a vacuum' stage. Ordinarily this is a good sign, as it means air bubbles are being sucked out of the reservoir/lever, but in this case, the bubbles were coming from the where the hose joins the syringe. I could see that lower down where the hose was attached to the bleed port, there appeared to be nothing coming through at all.
Much frustrated buy the never-ending stream of air bubbles and not being able to get a vacuum before running out of syringe travel, I tried swapping syringes and the same thing happened. These are brand new syringes from an Avid bleed kit I purchased recently. I also tried a Rockshox syringe I had lying around and it malfunctioned similarly.
I've bled Avid brakes before and not had this problem - what I am doing wrong? Is it possible that there isn't any air in the system and that cranking on the syringe really hard just pulls air through the hose join? In this case, why are my brakes feeling spongy and needing the contact point adjustment dialled all the way out to stop the levers coming all the way in to the bars (ie no brakes)?
