Quick rundown of first ride last weekend!
It was a rather late night getting the touch points and suspension settings adjusted, so I thought it was going to be a real gumby of a ride next day.
Two fuckwits moments though. In my half asleep haste I did put the front tyre on backwards, and the grips were on the wrong sides.
Surprisingly, the Fox recommended DHX2 settings felt bang on and leaves little room for more tweaks. The forks are what I had on the Slayer, but with the lowers swapped out for 29er. Cyclinic gave the bushings a good burnish prior to shipping them down, and I feel like I need the next spring rate up. More tuning needed for the fork.
Now back to the frame..
Numbers wise the reach is about 20mm longer, and the chainstay about 20mm compared to the Slayer. So my weight remains quite central and it's a familiar feeling. I still have to slide my hips forward and back more aggressively compared to the shorter bike. There is zero cable noise when using foam tube liners inside the frame. The longer chainstay makes it noticeably more difficult to pull manuals
Front end felt noticeably high and typical of the high stack number, plus probably a 29er thing I'm not used to yet. I will see how it fairs on a few more rides and maybe drop 5mm from under the stem. For taller riders I imagine this frame will be good as you no longer have to run lots of spacers which reduce your reach.
The marketing spiel goes on about how they go to the trouble of forging, machining, and aligning the rear end linkages etc. Can attest that everything fit together very exactly during the build, and the breakaway force on the suspension is exceptional. The rear of the bike is really noticeably stiff, and QUIET with very little chain noise. It is a joy to plow through tree roots and not have the back wheel deflect or the chain make noises. I did add mastic tape to the inside of the seat stay at the cassette, and chain stay near the chainring; maybe that helped?
Currently running the flipchip in the HIGH setting, which combined with a 175mm fork gives 63.8deg head angle. Feels great and for all round use I wouldn't want it any slacker or the bb any lower.
This is the heaviest bike I've owned at 17.5kg. Not sure how others are building this up to be around the 15Kg mark, sometimes with a larger frame. Surely their carbon rims, bars, lack of tyre insert and coil suspension cannot save 2.5kg?? Either way, the weight (800g more than the slayer) is not noticeable, and the suspension is active but still feels efficient enough to get up climbs without too much effort.
Super stoked at the moment and will continue to share updates.
