northvanguy
Feels that way. Sales on Phantom and Rune.
Titan would be the bike I’d be looking for.
Will keep watching. Cheers
Do you go through the full process laid out on the Silca website when waxing your chain? Seems like an awesome product , but also a pretty onerous procedure compared to dousing the chain with some Rock ‘n Roll Gold.Sorry been busy working, and riding
But thanks for your interest so here are a few updates!
1. Cable routing for derailleur was terrible and causing unreliable shifting. I jumped on the AXS bandwagon and instantly noticed the weaker clutch and noisy chainslap. It was so bad I wasn't even enjoying riding the bike as much.
Then I found this: https://madronecycles.com/products/super-shims
(sourced the relevant parts for the kit myself off Fleabay)
Also found a part of the chainstay was getting the shit smashed out of it by the chain, and have added mastic tape to cover this area:
End result, the bike is quieter than even when I had Shimano running gear. The bike is actually a joy to ride again.
I will soon have a bunch of leftover parts for the Madrone kit and set up a post to distribute them to fellow burners if there is interest.
2. Some Ti-bling to replace the rusty stem bolts. Leftovers fit the brakes too; bonus!
3. Deep dive into hot waxing the chain. Recommend not using the default stovetop pot method as it takes bloody ages for water to melt the wax in packet. Missus was also cussing me to not leave a mess in the kitchen.
Will buy a cheap rice cooker for next time and pour the wax directly in.
2 rides later and the chain is still dead silent and dirt just hoses off the entire drivetrain. Recommended.
4. Fork was feeling noticeably softer/slower than 6 months ago. Thought I was just getting fat.
During the 6 month service I found the Smashpot spring had shrunk about 2mm in length, causing me to be running near zero preload. Once this was rectified, on next ride it literally transformed the feel of the bike.
As it turns out this is not an uncommon issue with the Smashpot springs, so best to check yours. Stock length should be 400mm but they can be a few mm less from new, and settle after use.
5. Been riding! Last week was end of season at Lake Mountain and boy was it a misty beautiful weekend breaking out into sun from the halfway point. The 20mm of rain made everything extremely tacky and is one of the best rides I've had there. Hope you got to enjoy it!
That sounds a lot more manageable (except for the cost of their liquid wax top up stuff).I think I did... except I didn't use their expensive grease strippers or the stuff that turns grease into wax.
Just ran the chain through 2x loads of mineral turps in the ultrasonic cleaner, then 2x loads of meth spirits, and final rinse with water. Seems to have got rid of enough grease that the wax stuck like shit to a blanket.
Apparently once you've done the grease strip once, you don't need to do it again. Just clean dirt off and hot dip again. The intermediate rides you can use their liquid wax to topup as-required.
@teK-- what do you make of the Rulezman ZeroBack contraption?
Ya no bashguard is a deal breaker for me I think as I always smash the sh*t out of mine.
like all the concepts though.
Perhaps Titan v4 is UDH meaning could run transmission with the built into cranks bashguard as a solution.......
Still though the extra $$ for transmission plus the ZeroBack and still a very expensive adventure.
Old mate in Italy is kidding himself wanting $700 for that shipped to AUS.
Is there a reason a Transmission crankset and ring cannot be used with regular Eagle?
Different chainline, or are the teeth profiles or ring mount different?
Good point. There's always GX Transmission cranksets for sale on FaceBook as well so there must be some cross compatibility.
I'm just Titan curious at the moment............
I'm Sydney based so the options to see / test are very limited particularly as I'm a true Burner and in the XL department.
And it is an indisputable FACT that a quiet bike makes you a better rider.... which is why I think I've had enough with my current bike.
Not sure if pedal feedback would even be noticed on Titan if i hadnt been doing some research and stumbled across it and thought i'd ask
I ride with Onyx hubs. Exy, I know. I was warned about excessive pedal kickback. I noticed it (very) marginally on flats. Not at all on clips. Worth ever penny for the silence. And tech climbing.this deep dive to reduce pedal kickback, it's actually made me question how much of an issue it actually is when considered in isolation...
Just a pity they seem to be pretty hard to get here, unless you go for a complete wheelset via LB etc.I ride with Onyx hubs. Exy, I know. I was warned about excessive pedal kickback. I noticed it (very) marginally on flats. Not at all on clips. Worth ever penny for the silence. And tech climbing.
I was tempted by those as well, but same problem with availability. Would hate to think if I needed small parts for it.Just a pity they seem to be pretty hard to get here, unless you go for a complete wheelset via LB etc.
I run Onyx on several bikes, they pair especially well with a Pinon gearbox for a completely silent ride. I order them direct from the US and they have always been great to deal with, even spare parts haven't been a problem. Had an old 135mm spaced Zelvy hub that I remembered buying from someone here a long time ago and had a need to fit it to a 142mm frame, Onyx were very helpful in supplying an axle kit and some fresh bearings.Just a pity they seem to be pretty hard to get here, unless you go for a complete wheelset via LB etc.
Do you get them straight from Onyx or via Fanatik or another US distributor?I order them direct from the US and they have always been great to deal with, even spare parts haven't been a problem.
