Thanks mate. I emailed Keith Scott and he also reckons I can make it work with a mullet setup. Pretty much echoing what you said above. I'll probably have to go 150mm dropper or less, but that's what most of my bikes run anyway.Hey mate 172cm here, and my arms aren't particularly long for my height either.
Whether the Medium will fit you depends not only on the reach, but also the stack height, and how you're going to configure the bike.
I'm assuming you will set it up as a mullet? Also will you run a 170 or 160 fork?
The Banshee mullet charts assume a 160 fork, so if you go a 170 fork for example, that might help by shortening the reach by around 4mm. The stack height and head tube length on these are pretty generous. Unless you are riding steeps all the time, you may end up running minimal spacers and a 20mm (or less) rise bar. It's not the kind of frame to run lots of spacers just to bring the bars closer to you.
The titan has long chainstays, so if you run a 32mm stem then you will need to ride aggressively over the bars to get good grip out of the front tyre and stop it from lifting on climbs.
Compared to other modern enduro frames, I'd say the reach on the Titan is a bit shorter than average. Some people do go a size up on the Titan and just go super short stem with the saddle forward a bit more. (Dave Rulezman for example).
Another thing to consider is the seatpost insertion depth is not the best on this frame, so for your height it is likely you will only get 150mm drop and that is using a really low stack post like a Oneup V3.
Ultimately you can make this bike fit so long as you are clear what kind of bike you want... it is not going to be a super response whippy playful thing. Where it will shine is its high stiffness, and stability at high speeds.
I want a large - perhaps we can do a job lot…Now to look for a medium titan at a reasonable price..
Yep they are trying to clear out current inventory to make room for the new upcoming model.. plenty to be saved.I want an XL.
Ask distributor for a deal
They've been pushing 30% off rrp for a while. If you 3 get together for a group buy likely even better. Also there's an off menu option to get the frame with no shock which i saved another $600 at the time which was a great deduction.Think I need to see the new before I buy the old.
Have you seen any Titans on deep discount though?
As for the new Titan it sounds like still be quite some time away. Based on Keith's comments elsewhere I'm gonna speculate on changes they are likely to include:
Better seatpost insertion
Still no UDH, unless they shorten the chainstays by around 5mm to create clearance. Keith has been against UDH and the release of Shimano wireless probably makes his view an even more likely design choice.
Rather than just make the reach longer, have a +/- 10mm flip chip reach adjust headset.
Either more progression in the suspension or a flip chip to adjust end stroke progressivity.
XXL frame size.
Better chainstay rubber protection.
External brake hose routing option.
If most of those features dont matter to you then probably worth just going with the current model.
bulk buy for burners then? maybe we can get discounts if we get 3 from a dealer. I got my rune from rushys in qld. he was really good.
Can’t hurt to ask anyway. I’m in Canberra, I can see if Kye/Missing Link has any…
Cheers. I'm out for now. ThanksRushys got back to me. He hasn't got any in stock unfortunately. He also said banshee probably have no more stocks of the titan either - but will double check for me. @mittagongben your old stock in the US might be the only ones left. happy to take the convo offline if you prefer.
