Bargain buys thread
Switch
huskier headed gent
Moorebagz is keeping his so if any of you other impulse buyers don’t need your cheap Lyrics hit me up
northvanguy
Cheap Lyriks arrived, OEM, 2017, non-boost, no packing obviously, with a couple of tokens. Exactly what I expected, happy with purchase.
I didn't bother as I have a Boost Lyrik on mine but am jealous of the qr system over the thru axle that came on mine that require an allen key.
Sent from my SM-J250G using Tapatalk
Mywifesirrational
I was hoping the tokens would be in there. Star nut too for the steerer?
No star nut. little bag has x2 tokens (maybe plus another one in them already? haven't looked), x1 decal and safety instructions.
I am a fan of the non QR version myself, very clean looking. Always ride with multitool so it takes 10-20 seconds longer than normal to get a wheel off.
DMan
Bugger. The sales guy I queried said it would be in there. He did say he'd pay the freight if I had to buy one though, so that's nice. Me too for the NON QR. Doesn't break as my QR did and makes it harder to steal your wheel too.
tkdbboy
i have a 2017 150mm yari. I think i can maybe swap out the damper of the 27.5" lyric directly? Pretty sure they are the same.
Doing this to get charger damper in my current 29" fork before "possibly" building up a 160mm endurobro 650b bike....
Thoughts before i hit go on a $400 complete fork?
Should be fine as RS damper kits don't come size specific between 27.5 and 29 , and Yari and Lyrik are identical apart from Damper.
You should get the 2019 debonair air spring whilst you're at it.
oliosky
Thanks. Already got the yari debonair spring installed.
Stoked. Pretty much gonna 2 (1.5?) different wheel sized lyrics for $400!
Nambra
Just bought a pair of the lyriks. Will my Rtc3 charger damper from a pike fit?
Should do - the Rockshox spare parts catalog lists the damper / air spring part numbers as being cross compatible between the Lyric and Pike (and Yari in the case of the air side)...
I could be full of shit too.
Edit: Item 6 might be the problem though... Lyric only?
Lyriks do have a thicker wall in stanchion, now you mention it. Requires smaller token than pike.
Edit. They’re all smaller now to suit either (grey). Earlier pike ones (red) won’t fit.
smitho
I prefer the thru axle over the QR. Swap? Boost Lyrik.
Paulie_AU
Will give it a try when they show up. Might just stash em for bike build I want to do next year. So cheap worth it even if I buy Charger 2 and 170mm debonair.
Nambra
Similar thinking - bought a set of Fox Performance 34's last year from ze Germans for a steal, has the Grip damper and standard air spring. Throw an EVOL and FIT4 in it and it's as near enough to a Factory (without the Kashima).
LYRIK RCT3 A1 (2016), RC B1 (2016-2018), RC2 C1 (2019):
PIKE A1-A2 (2014-2017):
PIKE RCT3/RCT B1 (2018+):
https://www.sram.com/rockshox/technologies/bottomless-tokens
  • Black bottomless tokens are compatible with the following Solo Air forks:
    RS-1, SID, Reba, Bluto, Revelation.
  • Grey bottomless tokens are compatible with the following Solo Air forks:
    Pike, Lyrik, Yari, Pike DJ, BoXXer.
  • Dark red bottomless tokens are compatible with the following Dual Position Air forks:
    Pike, Lyrik, Yari.
Thinking SA vs DPA forks perhaps?
Of course I could still be full of shit...
I seem to be mistaken.
I’ve had red (wouldn’t call them dark red) come in non DPA’s. NFI any more.
Older ones for pikes are different, I say. More of an orange red, and definitely larger. I say they are discontinued, and not listed above. Can’t recall what went in my DPA pikes. It was years ago.
Nambra
Happy to be corrected - the grey tokens work with everything, the reds are Pike only, suggesting the Pike has slightly thinner stanchion walls as you said originally... I wonder how the air shafts are cross compatible then - the o-rings must be able to handle the variation?
Paulie_AU
Then add the vorsprung fractive and luftkappe and the performance improvement will blow your mind.
Did a bit of reading I don't need RCT3 on the Lyriks. I only want them for sending.
Now maybe need to sell the pikes before wife cottons on to many forks being in the house.....
