Will do, cheers mate.Have a read of this thread I've linked underneath, if you still have problems just ask more questions.
https://www.rotorburn.com/forums/index.php?threads/which-brake-adapter.314265/
Haha no, then I'd definitey deserve the fuckwit thread.Upside down?
Hey, easy done! Don’t ask me how I know.Haha no, then I'd definitey deserve the fuckwit thread.
I'll get some tomorrow, it's fouling by quite a lot, looks to me like the caliper needs spacing out by another 5mm at least.Some pics will help. How much is it fouling by?
2017 Fox Factory 34's.What forks?
That's a possibility, I'll look into it, cheers mate.There are posts that are 180 mount these days as well as the original 160 mount.
Do you have 160 mount forks and get a post to post mount for 203 designed for a 180 post mount fork?
You're bang on the money mate, cheers.This happens all too often....Fouling is because you definitely bought a 180 to 203 adapter. You need a 160 to 203. I literally just fit one to a Fox 34 Wednesday.
You Have This
YOU NEED THIS
Ahhh.... Don't forget that single crown forks are not rated for 203mm rotors. You run the risk of chewing out your bushes. This came directly from a mechanic at my LBS so it must be true.This happens all too often....Fouling is because you definitely bought a 180 to 203 adapter. You need a 160 to 203. I literally just fit one to a Fox 34 Wednesday.
You Have This
YOU NEED THIS
Wait... What?Ahhh.... Don't forget that single crown forks are not rated for 203mm rotors. You run the risk of chewing out your bushes. This came directly from a mechanic at my LBS so it must be true.
All single crowns according to said mechanic. My Lyrik definitely wasn't up to 203. Should have asked why the shop had an e-Trance with a 203mm rotor on a Fox 36?Depends on the fork doesn’t it BK?
This from the Fox website:
Maximum brake rotor diameter for all FOX forks except Step Cast 27.5in is 203mm. Step Cast 27.5in forks have a maximum rotor diameter of 180mm.
The RockShox website lists 203mm max for most of the 35mm forks and even the 32mm Sektor is rated for 220mm.
