Newton
Anyone had any luck pulling one of these apart, or know of a link to instructions on how to open one up. A friend of mine has one with a loose usb connector, looks like its come adrift from the main board and it will only work if you push the cable in super tight. May be able to re-solder or heat glue the connector back down if we can open it up, does not have any screws, pulled up the sticker on the back, no hidden screws under there either. Tried to get under the rubber seal around the outside, no luck - feels like it may have been snapped together and not designed to be opened.
Any help would be appreciated - and for the record I have two Garmin 500's and swear by them, the Brytons area cheap and nasty ...
