気が狂っている男
You could make the corner a multi sided (eg 4 way) spine...
I want to build a mini northshore like feature on the opposite side of the property to the wooden tabletop. 3 stage step up to a 1.4m drop to a dirt down ramp. Wooden rail berms on 3 corners of the property and another smaller tabletop but with a kicker for an upramp... Plus a tyre "rock" gardenWould love to see some more backyard timber/diy creations for inspiration.
May have mentioned previously, still thinking something down side of the house, say two small doubles kids can roll and learn to boost, onto wooden berm at bottom of lot to mini wallride across front fence.
Neighbours will love me..^ you know how to landscape!!!
Yes, that's my plan. It's a wooden kicker my mates and I built a while ago. That way I can pull it back over time. The tabletop will be dirt with sleeper sides to hold the dirt in place. That way I have the bigger wooden table to roll for beginners or (or gap as we get better) and the smaller one to gap.Will you gap the kicker to table top?
I have to start with everything being rollable, and will gradually extend and remove things as speed and skills build. Just have to remove some garden beds and a small tree or two to widen it.
This is good so keep it coming. Fuel for thought. And if there is another thread on here you'll never find it anyway using the search engine@schred the easy out is to just build a flat wall that you can. Ride up or jump onto. Then just let it grow as desired from there. The wall tide I described above was a few hours work for 3 dudes. The quarter pipe was a bit more, but I was teaching teenagers how to build it on a rainy day.
@rowdyflat I think this might be the thread...unless you are talking something from the long ago? At least there wasn't a other new thread created.
500mm wide is plenty and you don't want to go too thick in the top sheet as it will crack when you bend it or it will take a long time to form the radius. I've built one out of 3 sheet veneer ply 10mm thick all over, just means you need a few braces.Good inputs though his ply looks a bit thin. I've sketched up some plans and found a decent source of economical outdoor ply. Even checked gumtree for pre-built, mostly ratty stuff they should pay to have taken away. Just a question of ramp width. Wallet says 600mm brain says 900-1000mm.
