Did you do what I told you to do?I'm assuming you have used their app?
https://www.canecreek.com/products/suspension/tuning-field-app
Nope. Didn't have the time to spend on the trail tuning it. (2 young kids dictate the shit out of my bike time) Having said that, I've got the app, so i may use it now to fine tune it.Did you do what I told you to do?
.........I'd absolutely use the app - it demystifies the CC super-adjustability.
Ah delighted for ya mate. They are a tricky thing to set up. You need to firstly know what it is actually doing before being able to adjust it correctly. As above, the CC app is great as it explains what each issue actually feels like, and makes you adjust your way out of it.So, a few of you know I've been battling this Inline for a while now (JTmofo!) Well, i finally made a heap of progress! Turns out the whole "dialing in" some LSR etc had me fu@ked. In my mind, turning the dial right was adding dampening, or slowing the return of the shock. No, it was more like righty chattery, lefty plushy! I had 15 turns of LSR on it, and it was virtually un rideable from chatter, went back to 8 turns, boom, beautiful! Gotta admit, it seems a little backwards to me adding turns would speed it up, but hey, i am only a spray painter! It's not far off spot on now, I'm wrapped. Told ya JT, I'm trying! Cheers!
Sent from my HTC 2PS6200 using Tapatalk
Not sure what you mean? Turning the dial clockwise does add moreSo, a few of you know I've been battling this Inline for a while now (JTmofo!) Well, i finally made a heap of progress! Turns out the whole "dialing in" some LSR etc had me fu@ked. In my mind, turning the dial right was adding dampening, or slowing the return of the shock. No, it was more like righty chattery, lefty plushy! I had 15 turns of LSR on it, and it was virtually un rideable from chatter, went back to 8 turns, boom, beautiful! Gotta admit, it seems a little backwards to me adding turns would speed it up, but hey, i am only a spray painter! It's not far off spot on now, I'm wrapped. Told ya JT, I'm trying! Cheers!
I thought turning the dial clockwise on LSR would ADD dampening/slow the shock return, but it doesn't, it speeds it up. Seemed strange is all.Not sure what you mean? Turning the dial clockwise does add more
That is strange, Clockwise turns on the controls are adding dampening to the circuit and it should reduce the shaft speed because of it.I thought turning the dial clockwise on LSR would ADD dampening/slow the shock return, but it doesn't, it speeds it up. Seemed strange is all.
I switched from a CCDB air to an Inline Coil on my Norco Range and it's so damn good that the settings can be all over the shop and it's still stupidly plush. Haven't had any trouble setting up either shocks, they were both pretty close with the base setting on the CC website and have only required small tweaks from there. As has been mentioned, the most important part of the process is gaining a good understanding of what each setting actually does. My completely simplistic way of looking at it:I switched out the Fox Float X Factory on my Bronson to the Cane Creek DB Inline coil as I could never get the Fox dialled right. Best investment in my bike I ever did, don't think I'll ever go back to air again.
That's what i thought! No wonder i couldn't get the fu@ken thing sorted. Not sure about the other dials, but the LSR is def that way.That is strange, Clockwise turns on the controls are adding dampening to the circuit and it should reduce the shaft speed because of it.
I've got the same shock. And I'm sure it adds LSR damping when I turn clockwise.I thought turning the dial clockwise on LSR would ADD dampening/slow the shock return, but it doesn't, it speeds it up. Seemed strange is all.
How does the app work? I used to just set my CCDBA sag visually with the o-ring on the shaft as a guide. It can be time consuming with all the on/off/on/off but you get there.Hey guys! So I finally robbed a few banks (and took JT's advice) and sent this fu@ken shock up to NS Dynamics for an upgrade. Wowee, what a difference! It's like a completely different bike. Like riding a cloud. Apparently, because of my mud guts, it was taking too much PSI to keep the shock at the top, and therefore making it chattery/un rideable with the small bump. Cost me a fu@ken fortune, but well worth it. But now I have another question. Can I still use the CC app if I need to, now the air can/internals etc have been changed? It used to take 210-215psi to set sag, now it's 245! Any thoughts? Cheers!
Yep, new air can.I can't see why not, did they put the new updated aircan on it ?
Yeah, the sag wasn't an issue, it was the tuning. It asks you how it's riding, then gives setting suggestions to remedy the problem. Massive pain in the arse, as it wants you to ride the same section over and over, then come back and use the app for setting changes.How does the app work? I used to just set my CCDBA sag visually with the o-ring on the shaft as a guide. It can be time consuming with all the on/off/on/off but you get there.
That will most likely explain the extra air pressure you need.Yep, new air can.
