At least it not a gravel bike!
"Sorry not sorry", but you can't quite ever feel clean again...Did an early morning loop on a mates borrowed gravel bike.
Sorry not sorry. View attachment 387375
Did you notice the decal on the Scott's downtube?I’ll save you the hambo.
https://nsmb.com/articles/vanitys-pricetag/
Why is there no spew emoji? Why??
I've got some feedback for you,I'm going to assume the squeeky wheel got some grease as there's been silence for a while, as is normally the case with internet feedback.
You got any pics of the groove in the steer, it doesn't sound like a good outcome at all?I've got some feedback for you,
Canyon(Australia) has still far denied an issue with the headset but have sent me out a plastic sleeve, apparently its "extra protection".
Myself and a few others with this issue have bought a Ritchey 1.5" Upper intergrated headset bearing and IS52/40 bottom bearing. The issue is 100% with the compression ring and not locking on to the steerer tube when torqued corrently. The plastic sleeve is 1mm thick and sits between the compression ring and steerer tube.... so they definately know its an issue with the spectral but fail to acknoledge it as it has already created a 1mm depth groove on my steerer tube(half the circumference - fork side).
ChrisJC(op) had also received this plastic sleeve and he helped me out with the info)
*edited bottom bearing info
I've added it to the original postYou got any pics of the groove in the steer, it doesn't sound like a good outcome at all?
I'd be very careful with that steer like that if you do big jumps, that could easily start a large crack over time with the extra force.I've added it to the original post
If it's a 1mm grove then it's a total loss of 2mm because of how circles work. If the above was how you spoke with Canyon then I'm less surprised at their lackluster response.Tbh I've pulled it apart 6 times at the request of canyon to grease so I won't be pulling it apart anytime soon as I'm over it. Also its very difficult to take a photo of a small groove like that, it's something you have to feel.... show me how you would take a photo of a small little <1mm depth line with rub marks on a rough surface....
Its 1mm at max, could be less but I can feel a slight groove with my nail. Its only half of the circumference of steerer tube as originally stated so i dont see where you got the 2mm from.
I will be replying to serious concerns/questions ONLY.
You guys asked for feedback, there is obviously damage there and the reason is compression ring.
@Korbzy didn't start the thread. Don't see any reason to lock it as there seems to be an ongoing issue.Seems like you have gotten everything you want out of this so maybe the mods should just lock the thread.
Thats awsome news! The FB spectral group posted that was a recommended replacement. Maybe post up the exact type of bearings used so other people searching the forum for the same issue will have the info neededI have about 750km of hitting rocks on mine since I changed to the cane creek top cap and metal spacers. Including 20k VM of descending at Thredbo in Jan. Its been silent the entire time.
Ill pull it apart shortly to inspect and post results, maybe tonight
You have also been a bit of a d**ck to members who have been trying to help you by pointing out potential safety issues with you fork. Your clear lack of understanding of the fundamentals involved (when you take 1mm of material off a cylindrical object all the way around it totals 2mm) then attitude (with a post I see you have now removed, see my quoted post below)I've posted useful relevant info for the issue at hand, unlike both of your posts.
Why are you even posting in here? do you have a spectral or do you have this issue? or are you just looking to troll?
Yeah I'm here for a bit of trolling and also pointing out someone being a bit of a d**ck to members.If it's a 1mm grove then it's a total loss of 2mm because of how circles work. If the above was how you spoke with Canyon then I'm less surprised at their lackluster response.
@Litenbror - Fixed, I think...Created a 0.5mm deep groove in the steerer tube, reducing the outside diameter by 1mm.
I'm having trouble following this with all the editing and deleting of posts going on. I think you're right if it's 1mm half way round then it's only 2mm if the ends meet on a straight line through the centre (I'm sure there is a technical term for that)@Litenbror - Fixed, I think...
@beeb I believe it should actually be "Created a 1mm deep groove around half of the steerer tube and no groove on the back side which I haven't photographed so you can't see"@Litenbror - Fixed, I think...
