Chain line question
MAXXTRED
Squid
G'day
Currently have a 3x crankset that I'm thinking of ditching for a second hand 1x Crank set.
Do I need to make sure that the centre of the 1x is running the same line as the middle ring on the 3x ? Is it that critical.
Cassette is a 7 speed if I remember correctly....
Is there a chain line chart somewhere on the net that I can access?
Thanks very much
Sent from my SM-G965F using Tapatalk
MAXXTRED
Squid
Any reason you can't just keep the 3x crank and use that in the middle ring position? It'll save you buying a new crank set.
I keep bending the 22(inner most) and 32(middle ring)...
rowdyflat
chez le médecin
unless you are never going uphill 1x7 would be no good.
1x9 say 30 or 32 narrow wide X 11-40 isnt bad if you are strong.
MAXXTRED
Squid
Found a 1x11 Box one component groupset.
Might be worth upgrading to it.
I'm quickly learning that there's A LOT to learn about MTB. So many options
