Chamelion
Bike has a Hope Hoops pro 4 148 rear hub and is currently running a sram blackbox 6mm offset chainring. 12 speed cassette on the rear. Is that right? Or should it be running a 3mm owing to the boost hub? I do notice a little chain rub on the cassette in some gears... which Ive read could be due to that?
From what I understand the bike may not have had said boost setup from stock. The rear wheel has been replaced in its entirety recently, as has the cassette. The previous owner just hadnt gotten around to doing the cassette due to difficulty in finding stock.
Just need to replace it and dont know whether to replace it with the same one, or get a 3mm.
Would also appreciate some suggestions as to brands/model chainrings that are good.
Thanks
Thanks
