cheap and good wheel bearings source in lockdown
Haakon
has an accommodating arse
DT Swiss (OE Giant TRX 1 wheel set) rear hub - size 15x28x7. Enduro is the default choice I guess, but anyone found a cheap non bike specific source?
Any bearing shop will have that size. Go for a SKF, FAG or NSK.
link1896
Mr Greenfield
6902-2RS
Repack with quality grease from day one. Think of the manufacturers grease as corrosion prevention while in transit. If you mangle a seal, bend it back and make sure that’s facing the inside. If you want higher maintenance but less drag, no seals facing inwards.
Daniel Hale
She fid, he fid, I fidn't
6902-2RS
While he’s at it. -when you change frame linkage bearings, do you open up every new one, grease then place into frame?
Milpool
Have knuckles, will drag
Are bearing shops a good option for most frame bearings too? I've been looking at enduro sets for my old Giant, not sure if there's anything particularly special in there.
No. Its usually a pain to get a set of full complement bearings from a bearing shop. Much easier to hit up Duncan at diymtb.
EsPeGe
DIYMTB are awesome for sure but I've got a local joint that is just as good. I've never walked away without the bearings I went in for. That's here in Sydney, surely there must be other places round like that?
Jesus H Christ where? Please say Brookvale.
Labcanary
One potato, two potato, click
I've bought a set of bearings from here for a CB front hub, they worked a treat.
Sent from my SM-J250G using Tapatalk
SummitFever
Canberra Bearing Supplies in Fyshwick should get you sorted. 6902-2RS is a common size and they will typically have something from NSK or SKF (sometimes FAG). Expect to pay around $30 a bearing. Quality will most likely be higher than Enduro.
