gippyz
Frameset. Was considering full bike, but then i got all the parts to build it up. So decided to just go frame.Hell yeah!
Did you got a full bike or a frameset?
Just been told shipping is delayed until the earliest 7/10
Tyvm!
I did some calculation earlier, and I think it'll drop to around 336mm. It is on the low side but not too bad, especially with 155mm crank.
My current pole machine is supposed to be a 29er, but I just pop a 27.5 rear and its bb dropped to 340mm. Ride very well with 165mm crank.
Your dedication to making offerings to the God of Sled is noted.built a crestline up with the 465mm 29er dropouts and a 27.5 wheel for a 62 degree head angle with a dorado.
SantGnar Claus approves.Your dedication to making offerings to the God of Sled is noted.
The jump trail is epic.Going up to Ourimbah this Sunday, be good to get it some proper trails. Will report back![]()
News on your frameset?Frameset. Was considering full bike, but then i got all the parts to build it up. So decided to just go frame.
Just been told shipping is delayed until the earliest 7/10![]()
Just got it late last week. Haven't got time to build it yet. Will post some pics when i have.News on your frameset?
What shock did it come with?Just got it late last week. Haven't got time to build it yet. Will post some pics when i have.
Don't you get the feeling that an Ebike already feels really dead in the rear suspension?I built a Spec turbo levo up and very happy.
10 speed ,good forks coil shock spacers for boost rear and 27.5. Front and back to make
it more nimble on hand made tracks.
I found coil shock was better than air for pedal strikes on big roots.
Would definitely buy a Teewing frame though.
Apparently a super deluxe. But i haven't picked it up yet as the shock was (weirdly) shipped separately. I couldn't be bothered waiting for it as i already have a formula mod shock i bought for my old rune.What shock did it come with?
Ah so that's what the motor afterrun is for. Been wondering what is the point of it. Yes i did try to shift to a lower gear after i landed.If the motor afterrun is too long and you change to a lower gear, it will sometimes throw the chain off or change to a higher gear unpredictably.
The plus side is you don't lose momentum coasting over roots and rocks where pedal strikes are a thing.
My chain actually came off at a funny spot. It was stuck at the bottom half of the motor, between the chainring and the motor. Weird place to get stuck on? I don't think the guide on the idler would help preventing this.Looking awesome! You could try a stiffer spring but also maybe look into a progressive spring, works well on mine. I turned off over run completely, it felt unnatural and made timing gear changes difficult. I also tuned down trail mode quite a bit, it was way to powerful out of the box.
I thought I was old school running 11s, nice to see the the 10! The motor has so much grunt there is no way you need 12s.
You've also got the updated chainstay with the guide on the idler, hopefully that stops any chain derailments.
The more I ride this thing the more I'm impressed, I find it pretty playful, I can still hop and jib of small features no worries. The only time I notice the heft is if the back end steps out on me, but aside from that, i'm a full E-Bike convert.
Bought a Smashpot coil conversion for the Zeb, will be fitting this week. Going interesting to compare it to the DSD Lower-Runted airspring i've been running, its been pretty darn good!
