Arse. It looks 8mm, and it's a socket....You're 99% wrong.
That used on the end of the rebound rod to convert to 27.5".Arse. It looks 8mm, and it's a socket....
I am the 1%. Andrew Bolte for PM! :behindsofa:That used on the end of the rebound rod to convert to 27.5".
The black one is used for 27.5". The silver one looks the same as the one already on the rebound rod for 26".I am the 1%. Andrew Bolte for PM! :behindsofa:
What's the other one for?
Well smell my socks. Thanks you pair of chiggers.The black one is used for 27.5". The silver one looks the same as the one already on the rebound rod for 26".
If you look at the diagram in the bag it shows the different lengths on the rebound for converting.
:hug: No worries, also nice Orange, always liked the chunky looks of these.Well smell my socks. Thanks you pair of chiggers.
Cheers. I much prefer the chunky look of this to the 2013, which looks a lot more like a Five....not that there's anything wrong with that.:hug: No worries, also nice Orange, always liked the chunky looks of these.
Cable routing would work a treat with reversed brakes. There are guides along the shock mount, but if I use these, the cables will have to cross over right on top of the shock shaft.Ever since dirt did their thing on the Alpine 160 last year I've started to see the appeal of these bikes. That model was particularly gorgeous, in the black and orange.
You gotta get that thing finished and riding!
Also, can you get a close in on the cable routing on the top tube to swing arm area, they seem to fiddle with it a bit over the past few years, interested to see where it has come from in that time.
Sent from my Agora 4G Pro
cheers...I'm crap at remembering to check wear...and it always rubs through to frame on me. I will get around to trying it again though. Much prefer the look of running beside the HT.No idea if this info would help, but this is how I avoided the rear brake cable routing issue on the TBc:
A healthy amount of frame protection & zip tying the brake to the gear housing until it had to chase over & down the LHS. No rub anywhere over & down.
I should heatshrink it but CBFd bleeding the brake.
Because I wear the pants.How the hell do you get away with bikes in the kitchen? Mum throws a fit.
Cheers Elbo. Will look into that as an option. Ta mate.Nice build Moorey! Love Orange bikes, always wanted a Five.
With the 8mm socket for the Mattoc, apparently, according to the MTBR thread you can use a 4mm allen key on the inside of the same bolt, just gotta be careful not to cross-thread it putting it back together.
What about a special section for moorey?We need a speshul section for Oranges so I can ignore them.
Looks ok. For an Orangatan.
