born-again-biker
Is looking for a 16" bar
You can spray me with corrosion inhibitor anytimeYou're worth your weight in gold my friend, that sounds like a tough gig. :/
I did the same thing but opposite, didn't check the ad properly and got a 35mm stem that's useless for all my 31.8 bars.my nice stealthy Atlas bars turned up today, now I just have to find a 35mm stem that the fuckers will fit to
should have checked that before I dropped the cash...and 31.8 wont quite flare out that far
I love it when people ask what that smell is, and you reply with a confident answer like,Well hopefully I never owe you an invoice.
We have 2 'waste' treatment plants at work that are about the size of a medium truck.
Some times we have to climb down the ladder into them to check /fix the aeration lines.
The really fun times are when the level on the bottom is a bit higher than the top of your gum boots.
I'm with @Ultralord....if I'm swimming in shit, the office peeps can cope with a bit of odour.
Smokers? Gross. Worst smell ever.
I’ve been down and watched some undies come flyin out an inlet pipe........... somebody had shit themselves at work and flushed the evidence hahahaha!I love it when people ask what that smell is, and you reply with a confident answer like,
i was just fixing that macerator pump again, somebody has flushed another shirt down the shitter...watch how fast they take a step back when you mention effluent flows!~
@Minlak works there too?I’ve been down and watched some undies come flyin out an inlet pipe........... somebody had shit themselves at work and flushed the evidence hahahaha!
How does something come out of an inlet pipe? Did these shit-tastic undies go in the inlet pipe or out the outlet pipe? I'm worried you may not really be a tradie my man! We might need to get you to pass the ultimate test...you need to drive past @Haakon. Of you hate him, you are a tradie.I’ve been down and watched some undies come flyin out an inlet pipe........... somebody had shit themselves at work and flushed the evidence hahahaha!
I guess it depends on which end of the pipe you're standing at.How does something come out of an inlet pipe? Did these shit-tastic undies go in the inlet pipe or out the outlet pipe? I'm worried you may not really be a tradie my man! We might need to get you to pass the ultimate test...you need to drive past @Haakon. Of you hate him, you are a tradie.
He is obviously on the smoking end of the crack pipe! Out the in? #clowntownI guess it depends on which end of the pipe you're standing at.
Yeah haakers is a right cunt. Stupid lycra wearing soyboi. He should be paying rego and licencing fee’s like everyone on the road. Grade A dickhead.How does something come out of an inlet pipe? Did these shit-tastic undies go in the inlet pipe or out the outlet pipe? I'm worried you may not really be a tradie my man! We might need to get you to pass the ultimate test...you need to drive past @Haakon. Of you hate him, you are a tradie.
#tradiecnfirmedYeah haakers is a right cunt. Stupid lycra wearing soyboi. He should be paying rego and licencing fee’s like everyone on the road. Grade A dickhead.
You seem abit special mate so I’ll type this slowly for you....... the pipe that directs flow into the pit.........is called an inlet pipe.
The Ignore button is Bliss.Yeah haakers is a right cunt. Stupid lycra wearing soyboi. He should be paying rego and licencing fee’s like everyone on the road. Grade A dickhead.
I hope you aren't running those massive rotors on single crown forks?Ordered a set of Cura 4's, 203mm rotors, bleed kit, extra fluid, and knew I already had brake mount adapters. Everything went well fitting and bleeding. Hang on a second...
Guess who forgot to order a shifter mount...
The crank fairies moved them and are playing with your mind..... Bet they're gone tonight.Second confession inside a week. I've spent a fair bit of free time over the last 3 or 4 days looking in every nook and cranny of my garage and spare room for a set of non-boost 170mm XT cranks I had laying around. Hadn't been able to find them anywhere. Walked through my garage this morning and saw them sitting (in plain sight) on top of a workbench in the middle of the garage. As the saying goes - "Couldn't see for looking"
Is that the Mixmaster mount? They're not in stock anywayOrdered a set of Cura 4's, 203mm rotors, bleed kit, extra fluid, and knew I already had brake mount adapters. Everything went well fitting and bleeding. Hang on a second...
It is currently bodged with the remnants of a Shimano shifter that I cut the shifter part off, and filed the clamp to match the shifter mount I had. It's very rough but worked surprisingly well. I'll probably end up putting the proper mount on order ot getting it off zee Germans, but I'll see how my hack solution works in the meantime and see if I forget about it. Currently it works and it cost me nothing.Is that the Mixmaster mount? They're not in stock anyway
Can't argue with that!Currently it works and it cost me nothing.
