Bugger. All good.Ahh, yeah it's a DT alloy freehub so might be best to get another kit. Live and learn I guess. Thanks anyway
You're welcome! There's always a silver lining.Thanks! I feel much better now.
I never have run any off road tyres at those pressures. Around 30psi max.1994, 1.9” panaracer Dart I ran at 50-55psi. God you pinged off everything with elastomer suspension and 50psi in the tyres.
FattyAnyone go through the stage of pressure north of 50? Belting around on a old Kona cowan, anything less was pinch flat central and obviously higher pressures = leas rolling resistance so who cares if your bouncing off marble sized rocks. My shins hated me for all the slipped pedals I had.
Even now I run front 27F/30oddR. Tried lower and ripped front tyre off rims a few times and smashed rear rims. Still bonk the odd rear if I mess up (there was one section in derby, every bloody time resulted in a new ding and a burped rear tyre. @hifiandmtb to the trailside rescue with the oneup pump )
Wow. I run 19/25. But I'm just wee whisp of a thing.Anyone go through the stage of pressure north of 50? Belting around on a old Kona cowan, anything less was pinch flat central and obviously higher pressures = leas rolling resistance so who cares if your bouncing off marble sized rocks. My shins hated me for all the slipped pedals I had.
40/45 was fast in the 2000sI never have run any off road tyres at those pressures. Around 30psi max.
I could just about bottom a tyre out on the rim by pushing down with 19psi in there.Fatty
ah gee thanks man. It’s not fat its powah!
Seriously man, it feels good. Now to be fair on the front I'm running a black diamond butcher on a 30mm rim. But over 22 psi it feels skatey. The rear I run 25 because the rim is carbon and I don't want to hit the rim. On the alloy I ran 23 with an aggressor.I could just about bottom a tyre out on the rim by pushing down with 19psi in there.
How do you guys go pushing the front into corners with such low psi? No tyre roll? Flexy bikes give me the willies. Too much vagueness and squish
If I know I’m hitting berms all day and speed is up I’ll whack pressures up more, what I posted is for my local trails with mostly unsupported corners and lots of lower speed traversing.
DJ bike see’s 60psi, BMX 100psi.
I feel your pain. I've done this before with a shifter and lever. Bet you don't do it again. I now flat pack all my boxes into the bin.Just a small one. Bought a new SS cog for the dirt jumper but didn't have time to install so left it in the padded envelope, sitting on my desk. Went to install it today but couldn't find it?
Just realised I binned it thinking it was rubbish. Rubbish already been collected. F-wit.
I remember someone that was into road tyre pressures for MTB'ing then grumbled about the harsh ride and lack of traction.40/45 was fast in the 2000s
Friend who was new to MTB used the max pressures on his Minions as a guideline.I remember someone that was into road tyre pressures for MTB'ing then grumbled about the harsh ride and lack of traction.
At least it stopped pinch flats.
They’re accidentally close...it’s not some I care much forI don't see the problem...
But I'm sure others would have thought your confession would have been not aligning the decals on the front with the tyre info...
I'm 88kg, lightest I've been in many years. Been running 20F/24R, on 2.4F/2.3R based on the moar grip thinking. Gonna try 24/28 this week after reading here that I might be a fuckwit.How heavy are you for those pressures to cause understeer? At 80kg I race with 23F/26R on 2.5 tyres and apart from on super duper grip fast berms never feel squirm. I do run a DD rear casing though.
38F/44R with tubes on my reissues, felt pretty good the other day. I never ever ran an off road tyre above 45, used to always run both at 45 BITD.1994, 1.9” panaracer Dart I ran at 50-55psi. God you pinged off everything with elastomer suspension and 50psi in the tyres.
I’m about 80 kitted up. I only use EXO tasing mostly. I sit around 24/28 for general riding. I don’t ride as hard as most. Any less than that I’ll feel a little squirm in hard cornering (DHF/DHR2).I've also been running on the low side of pressures, I'm gonna up it u
You'll be right. I know it sounds obvious, but just be patient, watch and absorb the YouTube tutorials, and you'll be fine. \*Place holder.
I bought Cushcore. Waiting for the new tires from CRC to fit-up
