JEBBS
I just go bike ridingI don’t need chemical assistance to tube out.
You need a drunk therapist then!I don’t drink or listen to others.
Are you volunteering?You need a drunk therapist then!
Is there any other kind?You need a drunk therapist then!
Maybe you need cocaine high therapist...really high. So high they back you into a corner and railroad you for hours on end with an inescapable monologue about something you can't quite decipher, but damn it you know it is very important to them! They seem to pop up casually at parties. Don't go home with them.Is there any other kind?
Cue @mooreyI've got a minor one...
I've been chasing an annoying creak in my everyday frame. It is the seat post. I clean it, I grease it, I insert it, I clamp it...about a week later it's back. This has been going on since I got back from Perth. I was sure the post couldn't be getting wet (it barely rains) nor that dirty so fast. On Friday between job one and job two I was making the correction again and realised the post is bent very very slightly and it looks like I have been clamping bang on the bend.
I assume that the covid weight gain + riding a fair few KMs between jobs + being hell lazy/tired on those commutes so just rough riding on the sea over bumps etc has proven too much for the nuke proof neutron seat post. I always ride this post with a lot more than the minimum insert inside the frame.
So I am thinking of getting a dropper with under seat activation. Anyone got a suggestion that I won't need to sell a kidney for?
Cue @Nerf Herder
Even if they were, Thompson is going to exceed my interest cash wise. The one I'm running on the Scout is a work of art though.Cue @Nerf Herder
I still love and use them on a couple of frames without internal routing. KS supernatural, drop zone and eTen. Also a Thomson, but don’t think the non remotes are available any more
Shimano rotors come with an orange sticker that I assume says something like "Don't stick your finger in moving rotor". I took it off. I was aligning a new rotor on a pal's bike and discovered the bottom tab on the mount had split and was rubbing the rotor. I spun the wheel to listen to the exact source of the ticking sound and put my index finger in the opening just a little too much. Yep, took the top clean off it, some nail as well. Nice clean cut, lots of blood contaminating the pads now but found the source of the tick.
What’s the original post? Might be able to “fix it”. Out of interest is it on a Hardtail? Is it a bent cartridge/stanchion? Or is the mast bent? I suspect TranzX Posts will take KS parts, but also suspect the guide rod system is different. I’ve never tried, but I have a few in the recyc bin if you want to cannibalise.Even if they were, Thompson is going to exceed my interest cash wise. The one I'm running on the Scout is a work of art though.
I know ks had one for a reasonable price but I've only seen sold out and 100mm travel.
I’m guessing it’s not currently a dropperWhat’s the original post? Might be able to “fix it”. Out of interest is it on a Hardtail? Is it a bent cartridge/stanchion? Or is the mast bent? I suspect TranzX Posts will take KS parts, but also suspect the guide rod system is different. I’ve never tried, but I have a few in the recyc bin if you want to cannibalise.
Depending what dimensions you want. I most likely can build something. Think ETen or Dropzone/supernatural. Pretty sure I’ll be able to build a 125mm but above that will be pushing things. Might be able to build a Frankenstein post. Best to email.
re KS. we have a shipment landing after the 14th Dec ... but lots of backorders so prolly not in there.
ETen Levers in most sizes (30.9, 31.7, 27.2 ) are in there.
You'd be correct...I’m guessing it’s not currently a dropper
@Nerf Herder jus toying with putting a dropper on the bike I ride to/from work and shops on. Likely I'll just put another conventional post on and cut the current post above the bend and use it for slammed trips to slay townnuke proof neutron seat post
Hehe.Did my first and probably last sealant bukkake whilst using an air hose thingy with a dodgy pressure gauge. Exceeded 60psi by a fair bit going by the force of the ejaculation....Damn it was a loud bang Cleaned up the mess and reseated the tyre, all OK. Was funny AF to see the expressions of the innocent bystanders.
Were you jerking off your tyre at a public place?Did my first and probably last sealant bukkake whilst using an air hose thingy with a dodgy pressure gauge. Exceeded 60psi by a fair bit going by the force of the ejaculation....Damn it was a loud bang Cleaned up the mess and reseated the tyre, all OK. Was funny AF to see the expressions of the innocent bystanders.
Do you not?Were you jerking off your tyre at a public place?
