When you have Landrover brakes nothing can make them worse. But the upside is that every other vehicle's brakes feel super strong by comparison.Contaminated car pads and contaminated bike pads aren't the same. My old Landy constantly dripped fluid on the rotors with no difference in feel whatsoever.....If your bike pads even SNIFF fluid, they takr their bat and ball a go home.
Pump it up till you get 25-30% sag.I'm going to put this here because I tried a search and can't find the answer plus I was a bit of a fuckwit letting way too much air out of my forks and now in decent mode they bottom out!!:frusty: so I'll have a shock pump this week in the mail hopefully if t7 are with in their usual mailing time frame!! My question is how much psi should I run? I'm 80kg or what's the maximum for this fork it's a Fox 32 Float RL CTD Evo. I was going to just check what pressure was in it now and pump up until they felt firmer than they are now.
Any help would be appreciated :behindsofa:
Cheers,
Cam
I'd start at 20% for an XC forkPump it up till you get 25-30% sag.
I ran about 80 psi in a similar fork ( talas 140 evo ctd) as I liked it plush. Set the sag to 20-25% or so.I'm going to put this here because I tried a search and can't find the answer plus I was a bit of a fuckwit letting way too much air out of my forks and now in decent mode they bottom out!!:frusty: so I'll have a shock pump this week in the mail hopefully if t7 are with in their usual mailing time frame!! My question is how much psi should I run? I'm 80kg or what's the maximum for this fork it's a Fox 32 Float RL CTD Evo. I was going to just check what pressure was in it now and pump up until they felt firmer than they are now.
Cheers,
Cam
I am at Lake Mac near Morisset if you want to borrow one...I'm going to put this here because I tried a search and can't find the answer plus I was a bit of a fuckwit letting way too much air out of my forks and now in decent mode they bottom out!!:frusty: so I'll have a shock pump this week in the mail hopefully if t7 are with in their usual mailing time frame!! My question is how much psi should I run? I'm 80kg or what's the maximum for this fork it's a Fox 32 Float RL CTD Evo. I was going to just check what pressure was in it now and pump up until they felt firmer than they are now.
Cheers,
Cam
Thanks for the offer, mine should be here by mid week! I can't ride until the weekend so I should be fineI am at Lake Mac near Morisset if you want to borrow one...
With Fox forks I've found your body weight in kgs equals the number of psi you should start with. Then fine tune for appropriate sag.I'm going to put this here because I tried a search and can't find the answer plus I was a bit of a fuckwit letting way too much air out of my forks and now in decent mode they bottom out!!:frusty: so I'll have a shock pump this week in the mail hopefully if t7 are with in their usual mailing time frame!! My question is how much psi should I run? I'm 80kg or what's the maximum for this fork it's a Fox 32 Float RL CTD Evo. I was going to just check what pressure was in it now and pump up until they felt firmer than they are now.
Cheers,
Cam
But I am sure we have a legally binding contract! Good luck with the Anthem. Hopefully minimal posts in here.Placeholder post.
Bought a bike off eBay (09 Anthem X1).
Lol, possible bargain anthem was too tempting.But I am sure we have a legally binding contract! Good luck with the Anthem. Hopefully minimal posts in here.
Well I'll be damned, I cant remember the last time fox made a 'decent' fork :behindsofa:I'm going to put this here because I tried a search and can't find the answer plus I was a bit of a fuckwit letting way too much air out of my forks and now in decent mode they bottom out!!
Snigger..........thats the default settings on fox.Where's the dial for the "indecent" setting?
125 is max pressure ...... As stated set sag with the pressure that's what its there for very basic guide pump it up to your weight... Do you still need a shock pump or bought one? I have spare if you want.I'm going to put this here because I tried a search and can't find the answer plus I was a bit of a fuckwit letting way too much air out of my forks and now in decent mode they bottom out!!:frusty: so I'll have a shock pump this week in the mail hopefully if t7 are with in their usual mailing time frame!! My question is how much psi should I run? I'm 80kg or what's the maximum for this fork it's a Fox 32 Float RL CTD Evo. I was going to just check what pressure was in it now and pump up until they felt firmer than they are now.
Cheers,
Cam
