Confessions from the fuckwits
Nambra
Cook the pads, fuckwit.
That’s actually what I did after giving them a good bath. Sprayed them with alcohol then lit them up, followed by a good blast from a butane mini torch. Seemed to bed in ok so I think I saved them.
I don’t reckon that’s enough. Cook in a saucepan on high heat. You’ll see them smoke as contamination burns off. Best done outside.
Daniel Hale
She fid, he fid, I fidn't
agree’d but i much prefer a frypan to a saucepan, we aren’t making sauce, i keep the heat low, if you have a kitchen fan/flue, the chimney style can be done inside easy enough, get said frypan from funnies/salvos shop, the old steel ones are best, teflon shite, Al ok
Nambra
Noted, although I did keep the butane torch on them until they stopped smoking. They’re only 355 brakes and B01S pads which I’ve got more of if they are knackered.
Staino saucepan or frying pan. I always do outside on camping stove.
droenn
Fat Man's XC President
you're just doing this dry? I followed the process on MTB direct website, their method is to boil up in soapy water... didn't work great though.
Daniel Hale
boiling soapy water will destroy the resin pads, which i despise, but some round here seem to be quite fond of ;):rolleyes:
fatboyonabike
Captain oblivious
i just put a drop of dish washing liquid on the pads and rub them together at pace until they come clean, it rips the oil out of the pads, rinse+repeat!
Scotty675
Cable thief
Ive resorted to a pad burn 3 times. No pots or pans needed, aluminium foil straight on the cooker has worked the times I've done it. They do smoke a bit when they need cooking.
