There's a module they do as part of their apprenticeship, "How to piss every other trade off"Can I just say.
All you eleckys need to learn how to clean up after yourselves on jobs and fucken deburr shit. Fuck.
I actually just sold all my files and 5” grinder flapper disks to the fitting apprentice.fucken deburr shit. Fuck.
Haha, nice.I actually just sold all my files and 5” grinder flapper disks to the fitting apprentice.
As penance, you get one pocket deburring tool for everything now. For lifeI actually just sold all my files and 5” grinder flapper disks to the fitting apprentice.
I believe the technical term for that is whirly jig.As penance, you get one pocket deburring tool for everything now. For life
Engineers...cant even cook rice.My camping confession, no not camping. #2 is away at the same time with 8 non campers using our gear so some kit was shared out. Do you need the 600W inverter? Nope you can have it. What about the spare 120AH AGM? Go for it.
So I switch on the inbuilt inverter and plug in the rice cooker. Beeeeeeeeeeeeep! Huh? Try again, beeeeeeeeeeeeeeeeeeep! Shit. What is the rice cooker rated at? 400W. What is the built-in inverter? 300W. Shiiiiiiiit. Does anyone know how to cook rice without a rice cooker? Bugger.
Part deux...
Fitted up a new wrap around 270 deg awning on the camper. Original brackets were a bit flopsy bunny ears so I made new ones. In the process improving the design by adding gussets. Too wet for a trial run before setting off. Go to set up on the beach and one gusset is an interference fit with the first awning arm. Ok, cut it with the hacksaw. Hmmm. Really tight access. Look a bit longer, ok I can tension the 2nd arm and leave the first furled. Works goodly. Today I pulled the first arm around until it hit the offending gusset, made a strap between 1st and 2nd arm at that length and stretched it out. Canopy is still furled though about 50% instead of 100% and it is really good, enough wrap to add shade and let breeze through. Serendipitous win! Still a fuckwit for not testing at home, could have made setting up impossible. Lucky.
Noooo.....Don't trying this while in Japan or they will throw you on the next plane homeCooking rice in the microwave can be pretty fucking messy.
Invest in a rice cooker, even the cheap $20 generic ones do a worthy job and double as a steamer for dumplings.
Cooking rice in microwave is the Barista equivalent of serving up Nescafe Blend 43 to your customers.
If I can understand what it is in English then what challenge is left?
Must be a mech thing...Engineers...cant even cook rice.
If there was only one rice type, maybe….Cooking rice isn't rocket surgery.
2:1 water:rice ratio in a saucepan with a well-fitting lid, bring to boil then reduce heat. Cook for exactly ten minutes and not a second longer. Done.
Uncle Roger does not approveCooking rice isn't rocket surgery.
Our lovely rice cooker that is still in our appartment in Tokyo made THE BEST PANCAKES!!!!Invest in a rice cooker, even the cheap $20 generic ones do a worthy job and double as a steamer for dumplings.
