That's what I'd anticipated, but it ain't budging so I'm assuming the cap may needto be removed separately.Should just be self extracting. Cap is for crank bolt to push against.
The bloody thing won't budge! I'm worried about putting too much pressure/force on it.Start unscrewing that 8mm. It should get tight, then loosen off as crank comes off
Give it another crack. Doing it the right direction?That's what I'd anticipated, but it ain't budging so I'm assuming the cap may needto be removed separately.
Sent from my SM-G973F using Tapatalk
The opposite direction to that indicated by the arrow and torque, correct?Give it another crack. Doing it the right direction?
Make sure to post the resulting video in the fwits thread.Thanks for the help all much appreciated, will have another got later. Cheers.
After you have had a lay down / nap and recouped your strength?Thanks for the help all much appreciated, will have another got later. Cheers.
More like giving the Tourettes a rest.After you have had a lay down / nap and recouped your strength?
