link1896
Mr Greenfield
During lockdown I bought myself a 20 ton press and taught myself how to rebuild CSU’s following Oliver Majewski’s (Blue Liquid Labs) method.
Crowns make hideous creaking noises due to corrosion forming on the mating surfaces between stanchions and crown, and steerer and crown. Locktite 609 is the go to compound, but dougal over at Shockcraft has started using PVA. I’ll be trying pva soon, as fox’s paint is pretty delicate, 609 damages it very quickly.
Oliver is a dead set legend. We’ve had many technical conversations. We’ve both enhanced the method further.
A 20 ton press is marginal, 30 or beyond is really needed. And pneumatically controlled is desirable, you need three hands to do this.
Rockshox stanchions need the best part of 20T to remove. Steerers are barely an interference fit, I’ve had some forks a rubber mallet can get the steerer out. Stanchions seem to be a good fit.
Fox steerers need at least 20t to remove. Sometimes I’ve gotten stuck and had to redo as I didn’t have enough force to drive home.
This process is very tooling heavy. Everything is subtly unique. You need a lathe, a mill, and a very good eye for accurately measuring and checking tooling fit. One wrong move and it’s good night $600 csu. And with availability being an utter nightmare, this is a high risk game.
Every generation and year of fork is different. 2019/2020/2021 fox36 for example, just to get stanchions back into the crown, requires 6 unique drifts for the bottom end of the stanchions. Madness.
To press the stanchions out, you need a delrin or ultraHDPE block to engage the bottom face of the crown and a drift to thread into the top cap position. Thanks to summitfever for the generously donated UltraHDPE off cuts. You press the stanchion out via a drift engaged into the top cap thread, drift fit is critical when you’re passing the best part of 20t though 8-10 turns of fine thread!. Again, fox is up to their usual shinnanigans with odd ball threads. (The latest generation of Fox36 forks, foot bolt threads are a unique to fox thing)
And then there are steerer removal tools. Every bloody crown is different. Tooling again is a huge challenge.
