"someone will no doubt point out that the M7 is provided with a $40M segregated shared use cycle path, which the riders weren't using. Such a comment of course completely ignores the fact that the M7 shoulder is also designated for use by cyclists (and is clearly signposted as such)."
ScottD said:
This guy is a fool. There is a perfectly good bike lane to use there, and he goes and rides on a motorway.
Was having a chat to some local riders and they gave this bloke the nickname of 'white line warrior' cause he trains right on the white line of the lane.
My thoughts are somewhere between you guys.
There is a perfectly good cycle lane the whole length of the M7. If this guy had used it, he would be alive today.
Cyclists do have the right to use the breakdown lane on the M7, and yes, it is signposted, also with cycle stencils on the road.
But the fact is, we ALL know drivers make mistakes, and for a cyclist on a tollway with a 100kmh limit, that mistake is pretty likely to be a fatal one for the cyclist. I tend toward ScottD, he is very foolish to have been riding on the tollway when there is a cycle lane on the side of the road. But that does not reduce the tragedy.
Lebronmtb - the cycle lane does have other cyclists, often families. Also walkers use it. And it does meander a little at times around certain corner sections, meaning you are not able to just sit and crank hard as you would in the breakdown lane.
I ride the M7 cycleway about once a month and I would NEVER consider riding along the breakdown lane for exactly the reason that has unfortunately happened to this bloke. For the benefit of less interruptions and less corners he has ended up dead.
I NEVER trust a driver, not when the consequence is my life.
